Iron Sage Posted January 24, 2021 Share Posted January 24, 2021 What I am not entirely sure about, is if the +1 STR modifier is calculated directly to the weapons STR before STR is doubled and so becomes 10 if , or if it is added as a +1 to weapon after STR is doubled. I suspect it means he is STR 9 and that the extra STR is added after STR is doubled. This because the rules for pathogens says that +1 STR is added to the weapon. Yet this is still somewhat unclear to me since the weapon also doubles STR. It is not entirely intuitive that it is double STR to 8, then add 1 and it is not entirely clear to me. I am leaning towards the STR 9 interpretation instead of the STR 10., but it is possible I am erring on the side of caution. Maybe I am missing something glaring and it is clear. Maybe you guys know ? Link to comment https://bolterandchainsword.com/topic/368701-pathogen-on-lord-of-contagion-with-plaguereaper/ Share on other sites More sharing options...
Marshal Loss Posted January 24, 2021 Share Posted January 24, 2021 It'll be 4x2+1=9. You can find this example in the core rules: Example: A Space Marine Sergeant (Strength characteristic 4) is making an attack with a power fist (Strength characteristic x2) while under the effects of a psychic power that increases his Strength characteristic by 1. The two modifiers (x2 and +1) are cumulative and applied concurrently. The attack is therefore resolved at Strength 9 ([4x2]+1=9). Link to comment https://bolterandchainsword.com/topic/368701-pathogen-on-lord-of-contagion-with-plaguereaper/#findComment-5658562 Share on other sites More sharing options...
Iron Sage Posted January 24, 2021 Author Share Posted January 24, 2021 Thanks ! Link to comment https://bolterandchainsword.com/topic/368701-pathogen-on-lord-of-contagion-with-plaguereaper/#findComment-5658563 Share on other sites More sharing options...
Plaguecaster Posted January 24, 2021 Share Posted January 24, 2021 It'll be 4x2+1=9. You can find this example in the core rules: Example: A Space Marine Sergeant (Strength characteristic 4) is making an attack with a power fist (Strength characteristic x2) while under the effects of a psychic power that increases his Strength characteristic by 1. The two modifiers (x2 and +1) are cumulative and applied concurrently. The attack is therefore resolved at Strength 9 ([4x2]+1=9). I was pretty sure it should be str10 since it's an actual upgrade to the weapon you take before deployment and not something that changes its stats during the game Could be wrong but that was how i interpreted it anyways Link to comment https://bolterandchainsword.com/topic/368701-pathogen-on-lord-of-contagion-with-plaguereaper/#findComment-5658588 Share on other sites More sharing options...
Marshal Loss Posted January 24, 2021 Share Posted January 24, 2021 It'll be 4x2+1=9. You can find this example in the core rules: Example: A Space Marine Sergeant (Strength characteristic 4) is making an attack with a power fist (Strength characteristic x2) while under the effects of a psychic power that increases his Strength characteristic by 1. The two modifiers (x2 and +1) are cumulative and applied concurrently. The attack is therefore resolved at Strength 9 ([4x2]+1=9). I was pretty sure it should be str10 since it's an actual upgrade to the weapon you take before deployment and not something that changes its stats during the gameCould be wrong but that was how i interpreted it anyways Doesn't matter whether the modifier is on the weapon or the character: Apply modifiers in the following order: division, multiplication, addition, then subtraction. The x2 always comes first Link to comment https://bolterandchainsword.com/topic/368701-pathogen-on-lord-of-contagion-with-plaguereaper/#findComment-5658630 Share on other sites More sharing options...
Iron Sage Posted January 24, 2021 Author Share Posted January 24, 2021 Well, at least I am glad I asked the question since it also helped others. Had completely forgotten that passage in the Core book. Link to comment https://bolterandchainsword.com/topic/368701-pathogen-on-lord-of-contagion-with-plaguereaper/#findComment-5658650 Share on other sites More sharing options...
Azekai Posted January 25, 2021 Share Posted January 25, 2021 Well, at least I am glad I asked the question since it also helped others. Had completely forgotten that passage in the Core book. I believe it is also opposite how it worked in 8th? Which is weird. In math you typically multiply, then add. I think 9th makes more sense and is easier to remember. Link to comment https://bolterandchainsword.com/topic/368701-pathogen-on-lord-of-contagion-with-plaguereaper/#findComment-5658728 Share on other sites More sharing options...
Closet Skeleton Posted January 26, 2021 Share Posted January 26, 2021 I was pretty sure it should be str10 since it's an actual upgrade to the weapon you take before deployment and not something that changes its stats during the game Could be wrong but that was how i interpreted it anyways The weapon starts as x2, that means it doubles the user's strength. Pathogens add to the weapon's strength so it would become x2+1, its not (U+1)x2. Link to comment https://bolterandchainsword.com/topic/368701-pathogen-on-lord-of-contagion-with-plaguereaper/#findComment-5659338 Share on other sites More sharing options...
TrawlingCleaner Posted January 26, 2021 Share Posted January 26, 2021 It'll be 4x2+1=9. You can find this example in the core rules: Example: A Space Marine Sergeant (Strength characteristic 4) is making an attack with a power fist (Strength characteristic x2) while under the effects of a psychic power that increases his Strength characteristic by 1. The two modifiers (x2 and +1) are cumulative and applied concurrently. The attack is therefore resolved at Strength 9 ([4x2]+1=9). I was pretty sure it should be str10 since it's an actual upgrade to the weapon you take before deployment and not something that changes its stats during the gameCould be wrong but that was how i interpreted it anyways Doesn't matter whether the modifier is on the weapon or the character: Apply modifiers in the following order: division, multiplication, addition, then subtraction. The x2 always comes first While that is correct during the game, I'm not sure if it is the case for something that is added in the list building step before the game starts. Specific wording in the codex is: "In addition to the effects listed for that Deadly Pathogen, add 1 to the Strength Characteristic" (emphasis by me). A example would be a WLT increases a character's strength by 1 to 5 and they have a power fist. Their strength would be 10 when fighting with the fist rather than 9 because they start the game as strength 5 rather than 4+1 I had a quick flick through FAQs but couldn't find them clarifying it Link to comment https://bolterandchainsword.com/topic/368701-pathogen-on-lord-of-contagion-with-plaguereaper/#findComment-5659501 Share on other sites More sharing options...
Marshal Loss Posted January 26, 2021 Share Posted January 26, 2021 While that is correct during the game, I'm not sure if it is the case for something that is added in the list building step before the game starts. Specific wording in the codex is: "In addition to the effects listed for that Deadly Pathogen, add 1 to the Strength Characteristic" (emphasis by me). Strength Characteristic of the weapon Deadly Pathogens specify that you need to select a plague weapon to upgrade. It doesn't affect the model's statline. Either way, it doesn't matter. The rules don't distinguish between when different modifiers are added, they only spell out how said multipliers interact: Many rules modify the characteristics of models and weapons. All modifiers to a characteristic are cumulative; you must apply division modifiers before applying multiplication modifiers, and before applying addition and then subtraction modifiers. Round any fractions up after applying all modifiers. If a rule instructs you to replace one characteristic with a specified value, change the relevant characteristic to the new value before applying any modifiers that apply from other rules (if any) to the new value. If a WL trait said, e.g., "change your Warlord's str characteristic from 4 to 5", then a power fist would make it S10. If the trait is just "add 1 to your Warlord's str", then a power fist would make it S9. There's no difference between a modifier added before the game and a modifier added during the game. They function the same way. No FAQ is needed. Link to comment https://bolterandchainsword.com/topic/368701-pathogen-on-lord-of-contagion-with-plaguereaper/#findComment-5659517 Share on other sites More sharing options...
jgascoine011 Posted January 26, 2021 Share Posted January 26, 2021 While that is correct during the game, I'm not sure if it is the case for something that is added in the list building step before the game starts. Specific wording in the codex is: "In addition to the effects listed for that Deadly Pathogen, add 1 to the Strength Characteristic" (emphasis by me). Strength Characteristic of the weapon Deadly Pathogens specify that you need to select a plague weapon to upgrade. It doesn't affect the model's statline. Either way, it doesn't matter. The rules don't distinguish between when different modifiers are added, they only spell out how said multipliers interact: Many rules modify the characteristics of models and weapons. All modifiers to a characteristic are cumulative; you must apply division modifiers before applying multiplication modifiers, and before applying addition and then subtraction modifiers. Round any fractions up after applying all modifiers. If a rule instructs you to replace one characteristic with a specified value, change the relevant characteristic to the new value before applying any modifiers that apply from other rules (if any) to the new value. If a WL trait said, e.g., "change your Warlord's str characteristic from 4 to 5", then a power fist would make it S10. If the trait is just "add 1 to your Warlord's str", then a power fist would make it S9. There's no difference between a modifier added before the game and a modifier added during the game. They function the same way. No FAQ is needed. Did the BRB not saying something about you add in factors after the weapon. Link to comment https://bolterandchainsword.com/topic/368701-pathogen-on-lord-of-contagion-with-plaguereaper/#findComment-5659626 Share on other sites More sharing options...
TrawlingCleaner Posted January 27, 2021 Share Posted January 27, 2021 Strength Characteristic of the weapon Deadly Pathogens specify that you need to select a plague weapon to upgrade. It doesn't affect the model's statline. Either way, it doesn't matter. The rules don't distinguish between when different modifiers are added, they only spell out how said multipliers interact: You're totally right, my bad! Damn my 8th ed mindset! Strength 9 Scythe is still a rad scythe! Link to comment https://bolterandchainsword.com/topic/368701-pathogen-on-lord-of-contagion-with-plaguereaper/#findComment-5659985 Share on other sites More sharing options...
jgascoine011 Posted January 27, 2021 Share Posted January 27, 2021 Strength Characteristic of the weapon Deadly Pathogens specify that you need to select a plague weapon to upgrade. It doesn't affect the model's statline. Either way, it doesn't matter. The rules don't distinguish between when different modifiers are added, they only spell out how said multipliers interact: You're totally right, my bad! Damn my 8th ed mindset! Strength 9 Scythe is still a rad scythe! No difference between S8 and S9 unless the target is T9 Link to comment https://bolterandchainsword.com/topic/368701-pathogen-on-lord-of-contagion-with-plaguereaper/#findComment-5660041 Share on other sites More sharing options...
Iron Sage Posted January 27, 2021 Author Share Posted January 27, 2021 Which is, let's face it, very rare. So I suppose it is just a question if the ability is worth it or not. Maybe too expensive on a 5 attack Plaguereaper. Different if you go soup I suppose. Link to comment https://bolterandchainsword.com/topic/368701-pathogen-on-lord-of-contagion-with-plaguereaper/#findComment-5660099 Share on other sites More sharing options...
