Bloody Legionnaire Posted February 3, 2021 Share Posted February 3, 2021 Hello all, has anyone used non citadel/gamesworkshop produced bases that can speak to their quality? I've found some bulk 32mm bases on ebay that are about 15USD for 100 bases. That's a lot more cost effective than the GW route. Link to comment https://bolterandchainsword.com/topic/368875-non-citadelgw-bases/ Share on other sites More sharing options...
Azekai Posted February 3, 2021 Share Posted February 3, 2021 In my experience, as long as the bases look the same at a glance as GW, it's workable.You will likely get some warped ones, and sometimes you will have to buff down rough edges or bits of plastic flash. Link to comment https://bolterandchainsword.com/topic/368875-non-citadelgw-bases/#findComment-5663493 Share on other sites More sharing options...
battle captain corpus Posted February 3, 2021 Share Posted February 3, 2021 I use Green Stuff Worlds 32mm bases as they are insanely cheaper and fine. Though they are slightly (probably about 1mm?) lower in height but hey ho! BCC Link to comment https://bolterandchainsword.com/topic/368875-non-citadelgw-bases/#findComment-5663610 Share on other sites More sharing options...
Razblood Posted February 4, 2021 Share Posted February 4, 2021 I got 100 cheap ones on the bay of e and they're exactly the same as GW ones, just a bit rough around the edges and a bit smoother on top. Link to comment https://bolterandchainsword.com/topic/368875-non-citadelgw-bases/#findComment-5663717 Share on other sites More sharing options...
andes Posted February 5, 2021 Share Posted February 5, 2021 Coincidentally, I ordered a bag of 100 32mm generic bases from Amazon a couple of days ago (hooray for Ork Boyz Rebasingpalooza '21!). They're essentially identical to GW bases. Pics below, GW base is the one on the right. Link to comment https://bolterandchainsword.com/topic/368875-non-citadelgw-bases/#findComment-5664251 Share on other sites More sharing options...
