Halandaar Posted February 4, 2021 Share Posted February 4, 2021 I've had a look around online without much luck, I'm wondering if there is a tool (similar to the rollers and cutters made by Greenstuff World) that would allow me to quickly mass-produce the wax seal aspect of a purity seal; anybody know of any product like that? Link to comment https://bolterandchainsword.com/topic/368883-any-such-thing-as-a-purity-seal-stamp-or-cutter/ Share on other sites More sharing options...
Doghouse Posted February 4, 2021 Share Posted February 4, 2021 Might be worth taking a look at Blue Stuff. Link to comment https://bolterandchainsword.com/topic/368883-any-such-thing-as-a-purity-seal-stamp-or-cutter/#findComment-5663894 Share on other sites More sharing options...
beefeb Posted February 5, 2021 Share Posted February 5, 2021 I used blue stuff (equivalent), its probably the best way to go. You cab also use green stuff to make a mold....just press the purity seal into the green stuff to get your shape, let it cure, then use it as a press mold and hey presto, as many purity seals as you like. Link to comment https://bolterandchainsword.com/topic/368883-any-such-thing-as-a-purity-seal-stamp-or-cutter/#findComment-5664030 Share on other sites More sharing options...
Closet Skeleton Posted February 5, 2021 Share Posted February 5, 2021 The cross end on a screwdriver might do it. Link to comment https://bolterandchainsword.com/topic/368883-any-such-thing-as-a-purity-seal-stamp-or-cutter/#findComment-5664050 Share on other sites More sharing options...
Brother Desultor Posted February 6, 2021 Share Posted February 6, 2021 This guy shows how he made a custom punch to make the wax seals from green stuff - at 4:03: https://youtu.be/94HB06tcuKw Link to comment https://bolterandchainsword.com/topic/368883-any-such-thing-as-a-purity-seal-stamp-or-cutter/#findComment-5664338 Share on other sites More sharing options...
MaliGn Posted February 7, 2021 Share Posted February 7, 2021 I mean to make the wax seal all you need is a small blob of green stuff, a sheet of plastic and time, you make a small blob, squash it a bit stab the back end of a file or something similar into the middle (if you can find something to look like a skull or other symbol even better and then to leave to cure. You can make the strips out of paper and just superglue the combo of paper and green stuff to your model. Link to comment https://bolterandchainsword.com/topic/368883-any-such-thing-as-a-purity-seal-stamp-or-cutter/#findComment-5664659 Share on other sites More sharing options...
battle captain corpus Posted February 7, 2021 Share Posted February 7, 2021 I mean to make the wax seal all you need is a small blob of green stuff, a sheet of plastic and time, you make a small blob, squash it a bit stab the back end of a file or something similar into the middle (if you can find something to look like a skull or other symbol even better and then to leave to cure. You can make the strips out of paper and just superglue the combo of paper and green stuff to your model. This is yet yeah. I'm sure there are new tangled ways but sometimes the old tricks are still the best. There was a great article in White Dwarf back in the mists of time that explained this technique. But yeah, Blob of green stuff, squash it semi flat then indent and leave to dry. Boom! BCC Link to comment https://bolterandchainsword.com/topic/368883-any-such-thing-as-a-purity-seal-stamp-or-cutter/#findComment-5664752 Share on other sites More sharing options...
