Mathammer Request: Armorbane and Cluster Warhead
Indefragable
Mods: not sure if this should go into the AOD: Tactica section.
Looking for help (read: cheat sheet/formulas) calculating Armourbane and Cluster Warhead for the Xiphon.
Aka being able to calculate 5x Melta guns vs AV14 vs 5x Melta bombs, etc...
Thanks!
It's 58% to pen off a melta in short range, so 38% for a melta to hit and pen and 12% for a shot to cause an explodes result. 5 meltas would be 1.94 pens and 0.63 explodes.
Now, xiphons don't get armourbane. The average roll on a d3 is a 2, so you'd average 2 rolls on the damage table, giving you a 34% chance to cause an explode. But you need to pen first.
Thanks...I was more of looking for help with the formulas for calculating things like Armorbane or Cluster Warhead.
I couldn't tell you the formula, but this site has the percentage chance for numbers on 2d6m
http://www.travellercentral.com/rules/dice.html
Choose the AV value you want to beat and add the percentages up.
As for cluster warhead, there's no real calculation or formula. Average roll on a d6 is 3.5, which translates into a 2 for a d3. Just multiply that by the chance of your intended result like explodes (2x0.17) or immobilized (2x0.33).
