Shadrak Meduson Posted February 25, 2021 Share Posted February 25, 2021 I've managed to paint up 3k of AT so far, and have tons more planned.The story behind my force is the titans stationed on molech, supported by house marmaragon from molechs coastline. Tichinde, Dosjetka, Pearson73 and 10 others 13 Back to top Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/ Share on other sites More sharing options...
Pearson73 Posted February 25, 2021 Share Posted February 25, 2021 Saw these over on Instagram the other day and they look even better in these larger shots. Really solid work, the glow effects are nicely done indeed. Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5671307 Share on other sites More sharing options...
Shadrak Meduson Posted February 25, 2021 Author Share Posted February 25, 2021 Saw these over on Instagram the other day and they look even better in these larger shots. Really solid work, the glow effects are nicely done indeed. Thank you so much. I'm feeling the Titanicus burn these days! Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5671314 Share on other sites More sharing options...
The Yak Posted February 25, 2021 Share Posted February 25, 2021 Tasty Titans! Shadrak Meduson 1 Back to top Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5671360 Share on other sites More sharing options...
Mendi Warrior Posted February 25, 2021 Share Posted February 25, 2021 Very nice, it is an impressive force! I love the glow effect in particular and also the bases. I suspect you might have ran into some trouble with the legs on both the Warlords and Reavers. The left leg of the first Warlord looks funny, it makes me think you have put the back of the leg's lower part at the front instead. For the Reavers, the first one has left and right feet inverted and it looks like you have put the front toe armour at the back. These are quite common mistakes and don't detract from the overall results you achieved, so please don't hate me for pointing this out. Since you have tons more planned, I think it is better to check and avoid repeating the same mistakes on the next ones. I did post a few tips and tricks in my project log, here are some of the most relevant, there are more scattered across my various posts: http://www.bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/?p=5189546 http://www.bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/?p=5189551 http://www.bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/?p=5221057 Other project logs also have interesting tips and tricks, don't hesitate to make use of our collective experience. I would also drill the barrels on the laser blasters and turbo laser destructors like you did on the Reaver's gatling blaster. I advice the use of a 1mm diameter drill bit to perfectly center the initial drill. Eager to see your next steps! Shadrak Meduson 1 Back to top Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5671397 Share on other sites More sharing options...
Shadrak Meduson Posted February 25, 2021 Author Share Posted February 25, 2021 Very nice, it is an impressive force! I love the glow effect in particular and also the bases. I suspect you might have ran into some trouble with the legs on both the Warlords and Reavers. The left leg of the first Warlord looks funny, it makes me think you have put the back of the leg's lower part at the front instead. For the Reavers, the first one has left and right feet inverted and it looks like you have put the front toe armour at the back. These are quite common mistakes and don't detract from the overall results you achieved, so please don't hate me for pointing this out. Since you have tons more planned, I think it is better to check and avoid repeating the same mistakes on the next ones. I did post a few tips and tricks in my project log, here are some of the most relevant, there are more scattered across my various posts: http://www.bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/?p=5189546 http://www.bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/?p=5189551 http://www.bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/?p=5221057 Other project logs also have interesting tips and tricks, don't hesitate to make use of our collective experience. I would also drill the barrels on the laser blasters and turbo laser destructors like you did on the Reaver's gatling blaster. I advice the use of a 1mm diameter drill bit to perfectly center the initial drill. Eager to see your next steps! Thank you for all the points and tips, the warlord leg is a bit messed up yes, first titan I built. And the reaver pistons were a just me being nonchelant when putting it together I mainly drilled out solid round weapons, but I've considered doing it in the future on energy weapons as well. Ended up actually quite liking the subtle differences on the reaver legs Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5671416 Share on other sites More sharing options...
schoon Posted February 25, 2021 Share Posted February 25, 2021 Love the trees on the bases, and how you've worked the basing materials onto the feet and lower legs. Something you could still consider adding if you like, would be some smaller undergrowth under and around the trees. It would help the terrain of the base flow together better, and doing it in a mix of green and brown/tan would blend the base colors nicely. Shadrak Meduson 1 Back to top Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5671473 Share on other sites More sharing options...
Brother Dallo Posted February 25, 2021 Share Posted February 25, 2021 That’s an impressive lot of Titans. Thanks for sharing. Dallo Shadrak Meduson 1 Back to top Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5671479 Share on other sites More sharing options...
Shadrak Meduson Posted February 26, 2021 Author Share Posted February 26, 2021 Love the trees on the bases, and how you've worked the basing materials onto the feet and lower legs. Something you could still consider adding if you like, would be some smaller undergrowth under and around the trees. It would help the terrain of the base flow together better, and doing it in a mix of green and brown/tan would blend the base colors nicely. Thank you, I've considered doing the same, but I'm awaiting some tanks to add unto the bases. So after i put those on I'll see how much more I can add without overcrowding the bases. That’s an impressive lot of Titans. Thanks for sharing. Dallo Thank you for the kind words. Brother Dallo 1 Back to top Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5671585 Share on other sites More sharing options...
Mandragola Posted February 26, 2021 Share Posted February 26, 2021 This is a very nice looking Legio. Well done and welcome to the board. Shadrak Meduson 1 Back to top Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5671641 Share on other sites More sharing options...
Shadrak Meduson Posted February 26, 2021 Author Share Posted February 26, 2021 This is a very nice looking Legio. Well done and welcome to the board. Thank you so much, I find the community very welcoming in AT. Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5671655 Share on other sites More sharing options...
Lord_Borak Posted February 26, 2021 Share Posted February 26, 2021 Awesome stuff mate. I especially like the natural tones you've used on the bases and on the Titans themselves, they look very realistic. The trees are massive though! Has the Warlord with the Claw got his shins on backwards or am I going cross eyed? ..... Or shall I shut up? Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5671759 Share on other sites More sharing options...
Shadrak Meduson Posted February 26, 2021 Author Share Posted February 26, 2021 Awesome stuff mate. I especially like the natural tones you've used on the bases and on the Titans themselves, they look very realistic. The trees are massive though! Has the Warlord with the Claw got his shins on backwards or am I going cross eyed? ..... Or shall I shut up? Thanks, It's the thigh, not the shin Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5671810 Share on other sites More sharing options...
Shadrak Meduson Posted May 14, 2021 Author Share Posted May 14, 2021 So I finished my warmaster the other day, and tried it out in a game. It's freakin brutal in sheer amount of repair and shield regaining. Noserenda, The Yak, LameBeard and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5699464 Share on other sites More sharing options...
schoon Posted May 14, 2021 Share Posted May 14, 2021 Oooo. That's a very cool looking head. Off one of the Knight kits, is it? Shadrak Meduson 1 Back to top Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5699642 Share on other sites More sharing options...
Shadrak Meduson Posted May 15, 2021 Author Share Posted May 15, 2021 Oooo. That's a very cool looking head. Off one of the Knight kits, is it? Yes exactly, it's from the Cerastus Atrapos Knight from Forge World. I really didn't fancy the standard heads for it, so I started looking for heads before it came out. Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5699788 Share on other sites More sharing options...
SkimaskMohawk Posted May 16, 2021 Share Posted May 16, 2021 The atropos head works great. Wonder if there's a 3d print of them kicking around. Shadrak Meduson 1 Back to top Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5700070 Share on other sites More sharing options...
Lord_Borak Posted May 16, 2021 Share Posted May 16, 2021 Really nice!! That blue is especially awesome. Good use for the Knight head. I've already bagged my two spare Warmaster heads for my Imperial Knights. Shadrak Meduson 1 Back to top Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5700101 Share on other sites More sharing options...
Shadrak Meduson Posted May 16, 2021 Author Share Posted May 16, 2021 The atropos head works great. Wonder if there's a 3d print of them kicking around. Maybe, I guess a lot of designs are out there somewhere hidden. Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5700103 Share on other sites More sharing options...
Mendi Warrior Posted May 27, 2021 Share Posted May 27, 2021 Very nice! Shadrak Meduson 1 Back to top Link to comment https://bolterandchainsword.com/topic/369242-shadraks-legio-gryphonicus/#findComment-5703952 Share on other sites More sharing options...
