Captain Coolpants Posted March 2, 2021 Share Posted March 2, 2021 I've recently purchased the necron half of the indomitus box. And I love the atheistic of the skorpekh Lord and destroyers. Anyone had any success in altering their poses? I've given it a bash with 3 destroyers, but they seem kinda meh. I want like 9 of these guys, so any tips or inspiration would be cool! Link to comment https://bolterandchainsword.com/topic/369332-any-luck-customising-monopose/ Share on other sites More sharing options...
Daimyo-Phaeron Lenoch Posted March 3, 2021 Share Posted March 3, 2021 I’ve had some (admittedly accidental) success. I mucked up when building the two thresher destroyers, and swapped either arms or torsos, I forget which. The long and short is that the poses are ever so slightly different for it. It took some chopping to fix my mistake, and I doubt I could fail in the same manner again, but perhaps you could have some better success, esp when doing so deliberately. Welcome to the tombs, as wel. Link to comment https://bolterandchainsword.com/topic/369332-any-luck-customising-monopose/#findComment-5673615 Share on other sites More sharing options...
Captain Coolpants Posted March 3, 2021 Author Share Posted March 3, 2021 Thanks for the reply! Yeah they definitely need to be deliberately chopped and repositioned to make any real difference. Im just not imaginative enough to do something cool. I've put my attempt at the bottom. But they just seem odd to me, especially the one on the far right! Really reminds me of this meme https://images.app.goo.gl/jjA3CVBfmYoNjTWx9 Hidden Content Link to comment https://bolterandchainsword.com/topic/369332-any-luck-customising-monopose/#findComment-5673640 Share on other sites More sharing options...
Mandragola Posted March 6, 2021 Share Posted March 6, 2021 I actually had a go at this myself. I’ve built 12/9 Skorpekhs now. I built the first three straight out of the box. The second three I swapped around legs and torsos, which makes a bit of a difference. For the third set I cut the arms off at the shoulder ball joint and pinned them back on in new positions. I’ll do that again for the 4th.This wasn’t that easy but it was manageable. Mostly I built the guy and then removed the arms at the shoulder, very carefully, using a scalpel. The ball joints are really small so you have to drill really carefully too. I also found I needed to change the angle of the axe guy’s elbow, so that was cut abs repositioned raised above his head. Edit: here's a pic of my results so far: Link to comment https://bolterandchainsword.com/topic/369332-any-luck-customising-monopose/#findComment-5675038 Share on other sites More sharing options...
Trollbeard Posted March 6, 2021 Share Posted March 6, 2021 The reap blade conversion looks really good! And quite different from the original one! Good job on all three! Link to comment https://bolterandchainsword.com/topic/369332-any-luck-customising-monopose/#findComment-5675156 Share on other sites More sharing options...
01RTB01 Posted March 16, 2021 Share Posted March 16, 2021 I swapped arm poses on my second trio of skorpekhs and for me, it sufficiently changes their look. In fairness once they're on the table you don't really notice that anyways Link to comment https://bolterandchainsword.com/topic/369332-any-luck-customising-monopose/#findComment-5679176 Share on other sites More sharing options...
Mr4Minutes Posted March 17, 2021 Share Posted March 17, 2021 If you put the Skorpekh legs on the wrong peg it looks like they’re lunging forward. Found that out the hard way... Link to comment https://bolterandchainsword.com/topic/369332-any-luck-customising-monopose/#findComment-5679562 Share on other sites More sharing options...
Urkh Posted March 18, 2021 Share Posted March 18, 2021 My skorpekh legs are all over the place. I think only one of my three have all all three legs touching the ground. This is just from me messing up the assembly somehow. Link to comment https://bolterandchainsword.com/topic/369332-any-luck-customising-monopose/#findComment-5680055 Share on other sites More sharing options...
Captain Coolpants Posted April 1, 2021 Author Share Posted April 1, 2021 On a slightly different tangent. I've seen some pics online of people pretty much building wraiths upside down to make them look like scorpions, I've also seen a kit bash of a spyder and a triarch stalker to remove the goofy looking pilot. Just wondering if any of you have tried these? Link to comment https://bolterandchainsword.com/topic/369332-any-luck-customising-monopose/#findComment-5685355 Share on other sites More sharing options...
