Xenith Posted March 9, 2021 Share Posted March 9, 2021 Basically, can the reroll be used to reroll the dice for how many MW's are inflicted upon a unit by say, a Smite or other witchfir psychic power. Thinking on it, 40k is a permissive ruleset, that tells you what you can do in the game, not what you can't do. The reroll stratagem doesn't explicitly say you can use it to reroll the number of mortal wounds dealt from a smite, ergo, you cannot. Is my logic right in this? Link to comment https://bolterandchainsword.com/topic/369427-command-reroll-uses-for-mortal-wounds/ Share on other sites More sharing options...
Karhedron Posted March 9, 2021 Share Posted March 9, 2021 In 9th the stratagem specifically only lets you reroll the following rolls: To Hit To Wound Damage Save Advance Charge Psychic test DTW Number of attacks There is a case to be made that the number of MWs from Smite falls under the catageory of a "damage roll" and so might be eligible. Not completely sure on this one. Link to comment https://bolterandchainsword.com/topic/369427-command-reroll-uses-for-mortal-wounds/#findComment-5676269 Share on other sites More sharing options...
Dosjetka Posted March 9, 2021 Share Posted March 9, 2021 Wouldn't number of MW fall under the "number of attacks" category, instead? They're a special type of attack that ignores (most) saves but they're still an attack. Therefore you could Indeed re-roll the die determining the number of MW inflicted. Link to comment https://bolterandchainsword.com/topic/369427-command-reroll-uses-for-mortal-wounds/#findComment-5676274 Share on other sites More sharing options...
Xenith Posted March 9, 2021 Author Share Posted March 9, 2021 Wouldn't number of MW fall under the "number of attacks" category, instead? They're a special type of attack that ignores (most) saves but they're still an attack. Therefore you could Indeed re-roll the die determining the number of MW inflicted. The more I think on this the more you can't use it for MW's. MW's are clearly separated from attacks in the MW section of the book. Some attacks cause MW's in addition to other damage, but MW's on their own are not caused by 'attacks' as defined by the book (i.e. a hit roll procedure), so cannot be rerolled under that heading. It's not a roll to see how much damage is caused either, as each MW delivers one damage each, with no rolling to see how much damage each MW causes. Other rolls to see how many MW's are caused in an event are simialrly excluded - you can't reroll a dice on Tzeetch's firestorm (roll 9, 1MW for each 6) or stuff like Orbital Bombardment (on a 4+ a unit takes D3 mortals), despite these all being rolls to see how many mortals are inflicted. Link to comment https://bolterandchainsword.com/topic/369427-command-reroll-uses-for-mortal-wounds/#findComment-5676288 Share on other sites More sharing options...
Dosjetka Posted March 9, 2021 Share Posted March 9, 2021 When put that way, I can definitely see your point about why you can't re-roll the number of MW caused with a CP re-roll. I'll admit, my memory of 9th Ed. rules is a little hazy so I forgot that there was such a clear separation. Link to comment https://bolterandchainsword.com/topic/369427-command-reroll-uses-for-mortal-wounds/#findComment-5676331 Share on other sites More sharing options...
Xenith Posted March 10, 2021 Author Share Posted March 10, 2021 Yea, I'm still viewing 9th from the lens of 8th, where you could reroll anything. I think I've played as many games of 9th as 8th now though, but I think there's a lot more to read and digest. Link to comment https://bolterandchainsword.com/topic/369427-command-reroll-uses-for-mortal-wounds/#findComment-5676719 Share on other sites More sharing options...
