Layers
Arch69
Hello there.
So am working on some test models for Imperial Fists and I am using Yriel Yellow for the armour.
Ive noticed while airbrushing it on the more layers I add the more golden/darker it gets.
So my question is how do I keep a consistent colour across my army? So it doesn’t end up different tones/shades?
I know it’s a silly question but how do you keep track of layers while airbrushing? How many do you lot do?
https://bolterandchainsword.com/topic/369496-layers/
What you're seeing is a manifestation of the fact that when you're painting with an airbrush, you're effectively applying glazes due to the (lack of) thickness of the coat. It doesn't help that you're using a yellow, which are normally highly translucent. The answer is to carry on until you get a consistent colour and/or applying another coat doesn't cause the colour to change. :)
https://bolterandchainsword.com/topic/369496-layers/#findComment-5678162
Just keep a note on how many layers it takes you to achieve a colour you're happy with, which is what I do. Perhaps also keep a test model on your work surface to compare to on occasion if you're unsure whether you've hit the mark
What you're seeing is a manifestation of the fact that when you're painting with an airbrush, you're effectively applying glazes due to the (lack of) thickness of the coat. It doesn't help that you're using a yellow, which are normally highly translucent. The answer is to carry on until you get a consistent colour and/or applying another coat doesn't cause the colour to change. :smile.:
Thanks for the information. I’ll keep the test model for a guide.
https://bolterandchainsword.com/topic/369496-layers/#findComment-5678170
Just to add to that - also take a note on how much you thin the paint (ratio of thinner to paint, e.g. 2:1) and the pressure (e.g. 20-25 PSI) you use as well. By replicating the conditions as precisely as possible you'll ensure that e.g. 3 layers on any given day will be the same as 3 layers on a previous day. Good luck!
https://bolterandchainsword.com/topic/369496-layers/#findComment-5678173
Really silly question - but are you using the a primer first and is it the same colour for all your models?  Air brushing over different colours will give you very different results, so if you started over a white undercoat you can expect the look to be very bright at first until you add more layers.  Trying to get a consistent white (for example) when some of your models have black undercoats and others white is stupidly challenging with thin layers applied via an airbrush.
https://bolterandchainsword.com/topic/369496-layers/#findComment-5678214
I prime using wraithbone spray, then do a layer or two of Averland sunset through the airbrush first. This gives it an even yellow to base the yriel on. After that I do somewhere between two and three coats of yriel through the airbrush until it looks good enough as I like it. I pre-thin the yriel yellow in an extra paint pot using tamiya X20-A acrylic thinner, so that at least each batch uses the same consistency of yriel. I think as long as they're reasonably consistent and you follow about the same formula, it'll look fine enough after recess shading and highlights.
I haven't uploaded any newer photos yet, but there's some that are just basecoated in my Lamenters thread linked in my signature.
https://bolterandchainsword.com/topic/369496-layers/#findComment-5678449
Sone great information. Thanks I’ve just brought myself pots to mix in.
https://bolterandchainsword.com/topic/369496-layers/#findComment-5678611
