Deathwing Companion Model Size
Redassault5
Had a curious question if anyone had these units, how big are they compared to firstborn and Primaris marines?
I wanted to get some to make into my tabletop Firstborn Lieutenants as well as a Interrogator chaplain. Was wondering how big they were in size as I've seen the inner circle knights match up pretty well to terminators.
Thanks!
https://bolterandchainsword.com/topic/369511-deathwing-companion-model-size/
I have some, but I haven't built them yet as they're for 30k and I need to prime some of the components separately for bone and black.
They're probably similar in size to the Dreadwing interemptors, which are a little bit taller than a MK III space marine. So they'll be slightly bigger than most firstborn units, but they won't look out of place. Somewhere between MK III space marines and the new Chaos Space Marine kits.
Ah thank you, this is very helpful! I just wanted to make sure if I put an indomitus arm on one, it wouldn't look super out of place. I know the heads are same size
