logan_grimnar18 Posted March 18, 2021 Share Posted March 18, 2021 Last time I painted a vehicle, I used the old 'space wolves grey' primer spray. Is there anything like this still out there? Link to comment https://bolterandchainsword.com/topic/369576-painting-wolves-tanks/ Share on other sites More sharing options...
Ragnar69 Posted March 18, 2021 Share Posted March 18, 2021 The last version was called The Fang, but it's pop now. Maybe your local store still has some cans. Army Painter is selling a similar colour in cans I believe Link to comment https://bolterandchainsword.com/topic/369576-painting-wolves-tanks/#findComment-5680317 Share on other sites More sharing options...
Karhedron Posted March 18, 2021 Share Posted March 18, 2021 The Fang is a reasonable match for the old Space Wolves grey although not a perfect one. The good news is that it matches the pot of the same name. Here are a couple of tanks I have painted using the Fang cans. This image might be more useful. Most of the units are painted with the old Space Wolf Grey but the Hellblasters in the centre are painted in the Fang. To my eye, the Fang looks very close but just a smidge darker. To be fair, I don't think I highlighted the Hellblasters quite as heavily as the other units in this photo. If I highlighted a bit more heavily, the difference would probably not be noticeable. Bouargh, NightHowler and TiguriusX 3 Back to top Link to comment https://bolterandchainsword.com/topic/369576-painting-wolves-tanks/#findComment-5680338 Share on other sites More sharing options...
Grotsmasha Posted March 18, 2021 Share Posted March 18, 2021 Army Painter have a MASSIVE array of coloured primers that match old GW colours. Link to comment https://bolterandchainsword.com/topic/369576-painting-wolves-tanks/#findComment-5680362 Share on other sites More sharing options...
PeteySödes Posted March 21, 2021 Share Posted March 21, 2021 I feel like such a shill every time I do this on a primer thread but if you were using GW primers with what amounts to like 4 cans you can get a cheapo airbrush and get infinitely better and more reproducible results with like a stylenrez prime and a smooth basecoat of your choice. You will not be disappointed. Vassakov and Gederas 2 Back to top Link to comment https://bolterandchainsword.com/topic/369576-painting-wolves-tanks/#findComment-5681442 Share on other sites More sharing options...
sbarnby71 Posted March 22, 2021 Share Posted March 22, 2021 I feel like such a shill every time I do this on a primer thread but if you were using GW primers with what amounts to like 4 cans you can get a cheapo airbrush and get infinitely better and more reproducible results with like a stylenrez prime and a smooth basecoat of your choice. You will not be disappointed. Got to agree with this, I've got a £90 spraycraft airbrush and compressor and it's a game changer, I can base coat inside, any weather, does not matter if it's raining or snowing the base coat dries real fast (I even use the empty airbrush to blow clean air to speed up the drying), no bad smells. Ok the clean up takes a little bit of time, but I just make sure I've got 5, 10 or so items to spray and then it's worth it. I'd also say that if you're doing tank, then a cheap airbrush will work great for all you layering, so you'll get them done way quicker! PeteySödes 1 Back to top Link to comment https://bolterandchainsword.com/topic/369576-painting-wolves-tanks/#findComment-5681794 Share on other sites More sharing options...
Beef Posted March 28, 2021 Share Posted March 28, 2021 i second sbarnby71 in saying get an airbrush. it may seem daunting at first but it is a game changers esoecially for basecoats on tanks and larger models. Great for doing batches of troops also. there are a few good tutorials on youtube on ho to get started also. The main thing is making sure the paints are thinned to the right consistency. Once you have that down its easy enough to start out doing just base coats. Link to comment https://bolterandchainsword.com/topic/369576-painting-wolves-tanks/#findComment-5684086 Share on other sites More sharing options...
WrathOfTheLion Posted March 29, 2021 Share Posted March 29, 2021 (edited) I agree on the airbrush. I do the modern Russ Grey, which is a pain to get to look good with a brush. It's a breeze to airbrush vallejo german panzer grey, then GW russ grey air paint. Edited March 29, 2021 by WrathOfTheLion Link to comment https://bolterandchainsword.com/topic/369576-painting-wolves-tanks/#findComment-5684294 Share on other sites More sharing options...
sbarnby71 Posted March 30, 2021 Share Posted March 30, 2021 If you're unsure of the consistency of the paints, buy the "air" paints to get started, already pre-thinned, so you're good to go straight from the pot. Link to comment https://bolterandchainsword.com/topic/369576-painting-wolves-tanks/#findComment-5684546 Share on other sites More sharing options...
