Inquisitor_Lensoven Posted March 24, 2021 Share Posted March 24, 2021 I love their look and the first two particularly would go well with my regiment's nautical/naval theme. Any ideas for bits to make them fit an in with an IG army? Aside from IG guns and Aquilas of course. Link to comment https://bolterandchainsword.com/topic/369674-how-to-imperialize-raiders-ravages-and-venoms/ Share on other sites More sharing options...
GreenScorpion Posted March 24, 2021 Share Posted March 24, 2021 The first 2 vehicles are not heavily filled with specific xenos stuff, so you could replace the crew with guardsmen, change the weapons as you mentioned and add some imperial decoration/bits.I would perhaps remove or adapt some of the blades to make them look a bit less Dark Eldar related, a bit of greenstuff to turn the blades into something different like a helm in the back for example, essentially making it look a bit more like historical ships rather than the DE stuff. The venom could work similarly but its design is a bit too smooth compared to most imperial vessels, so it might look a bit out of place. N1SB 1 Back to top Link to comment https://bolterandchainsword.com/topic/369674-how-to-imperialize-raiders-ravages-and-venoms/#findComment-5682639 Share on other sites More sharing options...
sairence Posted March 24, 2021 Share Posted March 24, 2021 Insteas of regular Guardsmen on them you could see about crewing them with the Rogue Trader Voidsmen. They have a bit of a sailor vibe. GreenScorpion and N1SB 2 Back to top Link to comment https://bolterandchainsword.com/topic/369674-how-to-imperialize-raiders-ravages-and-venoms/#findComment-5682661 Share on other sites More sharing options...
Azaiel Posted March 24, 2021 Share Posted March 24, 2021 Are they supposed to represent actual ships on water or hovercraft? If the latter then maybe add anti gravity plates on the bottom like the Primaris vehicles. Inquisitor_Lensoven 1 Back to top Link to comment https://bolterandchainsword.com/topic/369674-how-to-imperialize-raiders-ravages-and-venoms/#findComment-5682682 Share on other sites More sharing options...
Inso Posted March 24, 2021 Share Posted March 24, 2021 Fill all the holes in the armour, remove any Eldar iconography, remove all the blades and hooks, change the weapons/crew to Imperial, remove the sails (either replace with some form of engine or at worst, replace them with square sails - like on a Viking ship). The ram on the front would look great as an Imperial Eagle :) . Azekai 1 Back to top Link to comment https://bolterandchainsword.com/topic/369674-how-to-imperialize-raiders-ravages-and-venoms/#findComment-5682796 Share on other sites More sharing options...
Inquisitor_Lensoven Posted March 24, 2021 Author Share Posted March 24, 2021 Are they supposed to represent actual ships on water or hovercraft? If the latter then maybe add anti gravity plates on the bottom like the Primaris vehicles. if only I had some spares lying around! Maybe I can use the landing gear from he Stormraven I'm building to fill that gap. walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/369674-how-to-imperialize-raiders-ravages-and-venoms/#findComment-5682820 Share on other sites More sharing options...
