jimbo1701 Posted April 1, 2021 Share Posted April 1, 2021 Hi folks. Trying to get my head around the primaris kill teams as I’m building models at the moment. Wondered if I could get some clarity? Are the wargear options on page 52-53 the entirety of how you are able to outfit your squads? Or do you also use the main datasheets to do so? I guess the main things I am trying to work out are: Melee options for the intercessor sarge Helix adept / comms array for the infiltrators Haywire mine for any incursors Multimelta for any eradicators Heavy bolter for any heavy intercessors Wasn’t clear to me if say a 10 man spectrum team could contain a comms array and a haywire mine, or if an indomnitor could contain a multimelta and heavy bolter if you had 5 heavy intercessors and 3 eradicators. Or if these weapon options just aren’t available in kill teams, just the primary units. Thanks for any help. Link to comment https://bolterandchainsword.com/topic/369795-primaris-build-options-help-please/ Share on other sites More sharing options...
Halandaar Posted April 1, 2021 Share Posted April 1, 2021 Check Page 51, the paragraph titled Wargear under Creating a Kill Team: "A model included in a Kill Team can be equipped with any of the wargear listed for that model under the wargear options on it's original datasheet" So yes, you can take an Infiltrator Comms array because that's an option on the original datasheet in Codex Space Marines. The same goes for Intercessor Sergeant melee options etc. Note that the minimum unit sizes for certain upgrades still apply (i.e. you can only take a Multi-Melta if you have 3 Eradicators in the unit). Link to comment https://bolterandchainsword.com/topic/369795-primaris-build-options-help-please/#findComment-5685165 Share on other sites More sharing options...
jimbo1701 Posted April 1, 2021 Author Share Posted April 1, 2021 Thanks Halandaar, that’s exactly what I was after. Much appreciated. Now I can get gluing ! Link to comment https://bolterandchainsword.com/topic/369795-primaris-build-options-help-please/#findComment-5685183 Share on other sites More sharing options...
