SvenIronhand Posted April 6, 2021 Share Posted April 6, 2021 Couldn't find a topic in the tutorials section, so here it is. One of the projects I've in mind is a Squat Hearthguard Command Squad for my Rymr 1st. My thinking is that I'd sculpt a Romanesque face mask like the following images onto Einherjar heads. How would you sculptors go about this? ranulf the revenant and N1SB 2 Back to top Link to comment https://bolterandchainsword.com/topic/369860-sculpting-face-mask-helmets/ Share on other sites More sharing options...
apologist Posted April 7, 2021 Share Posted April 7, 2021 This looks like a nice project to start with sculpting, as the style is clean, sharp lines with little relief. I'd suggest that you start by gathering source material – find as many artworks or examples of norse/saxon-style masks that you like the look of. Look for simple, iconic shapes and marks; don't go for very elaborate knotwork at this stage. With the source material close to hand, I'd lay a small ball of ProCreate or Brownstuff (less elastic than Greenstuff, they'll hold lines better and distort less) on the face, and gradually flatten it out into a shield shape on the face. If you only have Greenstuff, leave it to cure for a little while longer. After a few minutes to allow the putty to cure a little, I'd carefully use the the blade of a sculpting tool (you could use hte tip of a fine screwdriver) to indent the surface. Work slowly, and a little at a time to reproduce a specific example from your source artwork. Once you build up your confidence, move on to more complex shapes. Rinse, repeat and practise – that's really the key. Link to comment https://bolterandchainsword.com/topic/369860-sculpting-face-mask-helmets/#findComment-5686648 Share on other sites More sharing options...
space wolf Posted April 19, 2021 Share Posted April 19, 2021 Apologist is right. Additionally, if you're going to do more than one sculpting project, I suggest clay shapers or color shapers. They are generally the same thing, get a size 0 set. You can get them in hard and soft. I use both, it just depends on what you're trying to do. Link to comment https://bolterandchainsword.com/topic/369860-sculpting-face-mask-helmets/#findComment-5690309 Share on other sites More sharing options...
Theweewhitewolf Posted June 7, 2021 Share Posted June 7, 2021 I don’t know about sculpting but I bought these from Liber Daemonica. They’ve just arrived and look awesome: Link to comment https://bolterandchainsword.com/topic/369860-sculpting-face-mask-helmets/#findComment-5707697 Share on other sites More sharing options...
