Sylas_Ehlonite Posted May 10, 2021 Author Share Posted May 10, 2021 (edited) I finally have some actual Sisters to post in this WIP. I assembled 2 sisters and will keep working on the rest over the next few days. First up is the Sister Superior. I gave her the Chainsword and a Bolter because chainswords are just so dang cool. I had a bit of trouble getting the scabard in place, but it finally cemented in place. Also broke off the Rosette and had to re-attach it. Next up is the Simulacrum Imperialis. This girl was tough for me to visualize how she came together. I ended up putting her together out of order so that it would make sense. Once I could actually see how she would go together, she was pretty straightforward. I ended up putting a regular head on her instead of a helmet. I hope I don't regret that when it comes to painting. edit: https://imgur.com/a/RB5zoz2 I apologize for the bad lighting. I was on a porch with the only light from an overhead fan directly above me. edit 2: I tried to drill the barrels out after everything was assembled. I feel like all I did was make a mess. I will have to try again. Edited May 10, 2021 by Sylas_Ehlonite Montford 1 Back to top Link to comment https://bolterandchainsword.com/topic/369949-sylass-sisters/page/2/#findComment-5697655 Share on other sites More sharing options...
excelite Posted May 10, 2021 Share Posted May 10, 2021 (edited) For drilling the barrels you might want to have a look at the thread about fixing the helbrecht model, there was a nice video about it Edit: it’s somewhere in the black templars subforum Edited May 10, 2021 by excelite Sylas_Ehlonite 1 Back to top Link to comment https://bolterandchainsword.com/topic/369949-sylass-sisters/page/2/#findComment-5697758 Share on other sites More sharing options...
ValourousHeart Posted May 12, 2021 Share Posted May 12, 2021 (edited) My technique for drilling bolters is to start with a pointed round file. When I drill out the barrel is taken case by case, if the position of the gun is to close to other parts of the model, I'll drill the barrel before assembling. Step 1 - After cleaning up any mold line across the barrel, I use the point of the file to create a pilot hole. Just a little intention to give my small drill bit a point to rest in. I usually roll the file between my fingers to make sure the mark is well established. I find that I have the most control with the round file for this part. Step 2 - I drill from the side of the barrel. On the model there is a small depression on either side of the barrel. I don't push all the way through. I drill both sides to roughly the middle. And once the hole is complete then I use the bit like a file to smooth out the bore. Run it back and forth straight through. Do not try to change the angle. Step 3 - line your bit up with that indent you made on the tip of the barrel in step 1. Slowly drill in until you break the tension into the bore you drilled in sept 2. Step 4 - clean up the holes using the drill bit as a file like you did in step 2. When painting make sure you get a little bit of lead beltcher or what ever color you are using for the metal gun bits in the holes while you are painting the rest of the gun. Same goes for the Nunl Oil when you are applying the wash. Be careful not to clog up the hole with either paint or wash. I don't highlight the hole, because I want it to remain dark. EDIT - You'll get better at this the more you do it. So don't be to hard on yourself for the first squad. And even once you get proficient at this, you are still likely to screw one up in the future. So take your time every time. Edited May 12, 2021 by ValourousHeart Sylas_Ehlonite 1 Back to top Link to comment https://bolterandchainsword.com/topic/369949-sylass-sisters/page/2/#findComment-5698744 Share on other sites More sharing options...
Sylas_Ehlonite Posted August 23, 2021 Author Share Posted August 23, 2021 It has been several months since I did anything with the hobby, but I saw some Youtubers creating and got inspired to get going again. I decided to try out basing for the first time and am following the tutorial by Watch It Paint It on YouTube: https://youtu.be/sTdyK6EtTTM Step one: is to cover each base with Stirland Battlemire to give it a nice muddy undercoating. https://imgur.com/a/evgqaC0 Coming up after this dries I will: Step two: they call for Dry Brushing Steel Legion Drab. I have Mournfang Brown and am hoping it is close enough to work well. Step 3: will be a wash of Agrax Earthdhade Step 3: Apply Static Grass Step 4 Apply Green Tea leavings for leafs/green debris Link to comment https://bolterandchainsword.com/topic/369949-sylass-sisters/page/2/#findComment-5733727 Share on other sites More sharing options...
Sylas_Ehlonite Posted August 24, 2021 Author Share Posted August 24, 2021 Finished up the bases for my Battle Sisters Squad. I am very happy with how these turned out. We'll have to see what they look like with actual models on them, but I think they look pretty good for a first attempt. I will paint the rims black once I finally put the models in place. https://imgur.com/a/HeN2O2P Link to comment https://bolterandchainsword.com/topic/369949-sylass-sisters/page/2/#findComment-5734338 Share on other sites More sharing options...
Dread Posted August 25, 2021 Share Posted August 25, 2021 Mmmm cookies! Seriously tho they look great. Nice texture and colors. Be proud. Sylas_Ehlonite 1 Back to top Link to comment https://bolterandchainsword.com/topic/369949-sylass-sisters/page/2/#findComment-5734701 Share on other sites More sharing options...
