Balerion84 Posted May 10, 2021 Share Posted May 10, 2021 I'm starting with HH, we had our first game over the weekend - 1000pts ZM, DA vs WB - and I have a question that I can't find the answer to by googling. Can I take Deathwing Companions with Corswain? The book says, they attach to a Praetor or Legion Special Character. BS says I can't take them. Doesn't Corswain count as Special Character? Is there a difference between special and unique? Like in real life, where you are unique, but not special? Link to comment https://bolterandchainsword.com/topic/370224-corswain-and-dw-comps/ Share on other sites More sharing options...
m_r_parker Posted May 10, 2021 Share Posted May 10, 2021 In short, yes you can take DW Companions with Corswain. He fulfils all the criteria for the DW Comps. Brother Sutek, Balerion84, Helias_Tancred and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/370224-corswain-and-dw-comps/#findComment-5697981 Share on other sites More sharing options...
Calibanite Knight Angel Posted May 24, 2021 Share Posted May 24, 2021 Yeah this is something I ran into too. Corswain can take them (as per the book), it's most likely that whoever created his entry on Battlescribe simply missed it :) So feel free to take your Companions! Link to comment https://bolterandchainsword.com/topic/370224-corswain-and-dw-comps/#findComment-5702855 Share on other sites More sharing options...
Gorgoff Posted May 24, 2021 Share Posted May 24, 2021 Stop using BS as a rulebook. Adding point cost for units and manage the different army slots is all you should do with this tool. Allart01, SkimaskMohawk, Brother-Captain Gilead and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/370224-corswain-and-dw-comps/#findComment-5703134 Share on other sites More sharing options...
Claws and Effect Posted May 26, 2021 Share Posted May 26, 2021 Stop using BS as a rulebook. Adding point cost for units and manage the different army slots is all you should do with this tool. Going to second this statement. I often use Battlescribe as a quick reference tool for rules, but I verify with the rulebook and FAQ that they have it correct before I do so. If you don't have access to the book a given unit is found in you should definitely not trust that Battlescribe has it correct. Link to comment https://bolterandchainsword.com/topic/370224-corswain-and-dw-comps/#findComment-5703780 Share on other sites More sharing options...
Gorgoff Posted May 27, 2021 Share Posted May 27, 2021 Stop using BS as a rulebook. Adding point cost for units and manage the different army slots is all you should do with this tool.Going to second this statement. I often use Battlescribe as a quick reference tool for rules, but I verify with the rulebook and FAQ that they have it correct before I do so. If you don't have access to the book a given unit is found in you should definitely not trust that Battlescribe has it correct. I do that as well. Stats in particular are almost always correct but if you have a more complicated case always look it up in the books. Link to comment https://bolterandchainsword.com/topic/370224-corswain-and-dw-comps/#findComment-5704104 Share on other sites More sharing options...
Balerion84 Posted June 25, 2021 Author Share Posted June 25, 2021 (edited) Stop using BS as a rulebook. Adding point cost for units and manage the different army slots is all you should do with this tool.Thanks for the tip mate, but I'm not using BS as a rulebook. Since I'm new to HH and trying to orient myself in the rules, this discrepancy confused me a bit as BS entries are added by people who probably have better understanding of them than someone new like me. The book states 'special character', which I assumed is a named character (duh), but couldn't find any definition in the rules of this term, of what actually a special character is. There's a definition of Independent Character but not Special. And since BS didn't allow it for Corwin but did for Praetors (which the book names too), it made me pause if I missed anything. Also the book entry for Corswain says 'Unique, character'. Hence the confusion regarding terms. So I just wanted to be sure. Thanks for the confirmation everyone. :) Edited June 25, 2021 by Balerion84 Gorgoff 1 Back to top Link to comment https://bolterandchainsword.com/topic/370224-corswain-and-dw-comps/#findComment-5714337 Share on other sites More sharing options...
Gorgoff Posted June 28, 2021 Share Posted June 28, 2021 Stop using BS as a rulebook. Adding point cost for units and manage the different army slots is all you should do with this tool.Thanks for the tip mate, but I'm not using BS as a rulebook. Since I'm new to HH and trying to orient myself in the rules, this discrepancy confused me a bit as BS entries are added by people who probably have better understanding of them than someone new like me. The book states 'special character', which I assumed is a named character (duh), but couldn't find any definition in the rules of this term, of what actually a special character is. There's a definition of Independent Character but not Special. And since BS didn't allow it for Corwin but did for Praetors (which the book names too), it made me pause if I missed anything. Also the book entry for Corswain says 'Unique, character'. Hence the confusion regarding terms. So I just wanted to be sure. Thanks for the confirmation everyone. :) Ah ok. Yes, he can and yes he is a special character. As a rule of thumb: if it has a name it is a special character. Balerion84 1 Back to top Link to comment https://bolterandchainsword.com/topic/370224-corswain-and-dw-comps/#findComment-5714801 Share on other sites More sharing options...
