Captain Idaho Posted May 17, 2021 Share Posted May 17, 2021 I never got the Killteam boxed set so I have no idea, but how posable are the new Flayed Ones? The models look great but like the Skorpekh Destroyers models, they appear to be completely monopose. Since large units is generally the way to play, this is a problem for Flayed Ones. Has anyone gotten these models and found they are a little more posable than they appear? I've seen some cool conversions with Warriors covered in green stuff for skin which looks workable though the clawed hands would be the issue there. Really, I'd prefer the Flayed Ones box since it's easier to add new skin to then than from scratch. Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/ Share on other sites More sharing options...
Mandragola Posted May 17, 2021 Share Posted May 17, 2021 I haven't got any yet but posing them does look a bit problematic. There don't seem to be any optional bits even, unlike stuff like the new zombie sprue for AoS. From what I can see, it looks like some bits will be more swappable than others. For example, I can see that at least one of the arms connects to the head, so those two will kind of have to be used together. You might be able to cheat there by using a Warrior face instead though. I think that you'll be able to do quite a bit if you're creative, but it would take time and possibly result in more fragile models, which is a real issue for melee units like these. I have bad memories of kroot getting caught on every piece of terrain (made worse because they were always in forests) and I think these could suffer the same issue, which is caused by being covered in hooks. That's very likely to result in arms coming off all the time if they're not really strong. To be fair, these guys are replacing monopose finecast models. So in a way things aren't getting worse. I don't personally plan to get any right away as I'm not really convinced they're all that good for my list, but I expect I'll get some eventually. Can't say I'm really looking forward to converting them all. Captain Idaho and Halandaar 2 Back to top Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5700347 Share on other sites More sharing options...
Captain Idaho Posted May 17, 2021 Author Share Posted May 17, 2021 GW have always had a problem with this unit, since making modular models is going to be difficult when they're covered in human skin! I like to think GW could have done it nowadays though. I might have to see how the kits go and what I can do. Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5700362 Share on other sites More sharing options...
VoceNoctum Posted May 17, 2021 Share Posted May 17, 2021 They're monopose, so not really designed to be altered. The limbs are pretty thin though, so it'd probably be easy enough to assemble it "correctly" then cut & repose some of it. But yeah, everything is "keyed" rather than ball joint type attachments. At least from memory, it's been a bit since I put them together. I haven't primed/ painted yet, since 5 is only 5. Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5700406 Share on other sites More sharing options...
Daimyo-Phaeron Lenoch Posted May 17, 2021 Share Posted May 17, 2021 Also for your consideration, the new Flayed Ones cost on the order of 50 per 5 models. I would strongly recommend converting some instead. Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5700597 Share on other sites More sharing options...
Mr4Minutes Posted May 18, 2021 Share Posted May 18, 2021 I’m on the same train as Daimyo-Phaeron Lenoch. The dollar value of the kit does not match the point value of the unit/models. Twice as many warriors for a little bit less, and I’m sure somebody out there has a a bit that would work for the claws. That said, no fault to anyone who picks up the kit. Hopefully there’s some good conversion fodder in there. Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5700661 Share on other sites More sharing options...
Ahzek451 Posted May 20, 2021 Share Posted May 20, 2021 (edited) $50 ****** dollars for 5 flayed ones?? I've swallowed the GW price hikes for well over a decade but this....this is the first time I'm going to have to draw a line in the sand for a gorgeous new model kit for one of my primary armies. I will gladly fish for my old pewter ones. $200 for a full squad...sheesh! Edited May 20, 2021 by Ahzek451 Mr4Minutes 1 Back to top Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5701387 Share on other sites More sharing options...
dice4thedicegod Posted May 20, 2021 Share Posted May 20, 2021 Yeah, I’m sticking with converting indomitus warriors Mordas, Mr4Minutes, Son of Carnelian and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5701456 Share on other sites More sharing options...
Mr4Minutes Posted May 20, 2021 Share Posted May 20, 2021 Those are great conversions. Consider them “inspiration” for my conversions. Captain Idaho 1 Back to top Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5701481 Share on other sites More sharing options...
Captain Idaho Posted May 20, 2021 Author Share Posted May 20, 2021 (edited) My thoughts exactly. :) Great models and great idea. I'd prefer Claws to weapons though. What realistic source of claws would someone suggest? Edited May 20, 2021 by Captain Idaho Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5701546 Share on other sites More sharing options...
Daimyo-Phaeron Lenoch Posted May 20, 2021 Share Posted May 20, 2021 I’ve used (poorly) chopped up bits of plasticard for some wicked-looking cutting claws, which I would probably do again if I ever make some proper flayed ones (as opposed to my Flayer 6-limbed immortals). I can grab pictures later for you, Capt. Idaho Captain Idaho 1 Back to top Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5701657 Share on other sites More sharing options...
VoceNoctum Posted May 20, 2021 Share Posted May 20, 2021 Also for your consideration, the new Flayed Ones cost on the order of 50 per 5 models. I would strongly recommend converting some instead. I guess we'll find out in a couple days, but I haven't seen the price listed anywhere yet. They're certainly not worth $50 to me, but even if they're $40 that'll probably remove them from my interest. $50 for 10 would have been nice, and it's sort of irritating that they made them a 5 pack instead of 10 packs, but it is what it is. Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5701675 Share on other sites More sharing options...
NTaW Posted May 20, 2021 Share Posted May 20, 2021 (edited) I don't know how realistic this source could be, but I've always thought Sicarian Infiltrator claws would do the trick if you didn't want to fabricate something. There's only a few per box it seems so maybe a custom blade hand and this clawed grabby hand would be best. Know anyone who plays AdMech? Top right of the sprue: Attached to arm: Edited May 20, 2021 by NTaW Captain Idaho 1 Back to top Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5701697 Share on other sites More sharing options...
dice4thedicegod Posted May 20, 2021 Share Posted May 20, 2021 Just model a victim and you can hide the claws inside them! Mr4Minutes, Miek, Captain Idaho and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5701706 Share on other sites More sharing options...
BLACK BLŒ FLY Posted May 21, 2021 Share Posted May 21, 2021 Check out idicbeer on YouTube ! Captain Idaho 1 Back to top Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5701753 Share on other sites More sharing options...
Daimyo-Phaeron Lenoch Posted May 21, 2021 Share Posted May 21, 2021 IDICBeer 40k does have quite a few (ok, more like quite a lot!) excellent Necron videos. I tend to watch his stuff in bursts, so I don't know exactly what his flayed one video may or may not look like, but his conversion videos are high quality. Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5701778 Share on other sites More sharing options...
Captain Idaho Posted May 21, 2021 Author Share Posted May 21, 2021 Couldn't see a conversion piece on there for Flayed Ones (if someone can and links to correct myself that would be great!) but just watching now his tips on Skorpekh Destroyers conversions so they aren't all monopose. :) Regarding Flayed Ones, I'll take a goosey at Sicaran claws I might be able to procure. They look quite good and a little horrific. Link to comment https://bolterandchainsword.com/topic/370304-new-flayed-ones-and-poses/#findComment-5701822 Share on other sites More sharing options...
