Malakithe Posted May 29, 2021 Share Posted May 29, 2021 I dont have the new book yet but its on its way so can someone explain how the new version of Knights of the Cog works? Im thinking of including a Knight with my battalion Link to comment https://bolterandchainsword.com/topic/370447-knights-of-the-cog/ Share on other sites More sharing options...
DanPesci Posted May 29, 2021 Share Posted May 29, 2021 (edited) OK so to get how this works, you need to know how DI/Canticles work: "If every unit from your army has the adeptus mechanicus keyword (excluding agent of the imperium, unaligned, and KNIGHT OF THE COG units) this unit receives xxx." "Knights of the Cog" lets you give the "knights of the cog" keyword to one super heavy AUXILARY detachment (not super heavy detachment), as long as you have included an admech detachment prior to this. Which then makes it eligible for the above 'excludes') Basically this means you can include 1 SHAD per admech detachment, without losing any canticles/imperative on your admech. So yep, including a knight with your battalion should be fine! NOTE - Currently Metallica have a way of including several Raven knights without losing canticles, as long as you use the 'knight of the iron cog' start on every knight pre-battle. Edited May 29, 2021 by DanPesci Magos Takatus and Malakithe 2 Back to top Link to comment https://bolterandchainsword.com/topic/370447-knights-of-the-cog/#findComment-5704635 Share on other sites More sharing options...
Malakithe Posted May 29, 2021 Author Share Posted May 29, 2021 OK so to get how this works, you need to know how DI/Canticles work: "If every unit from your army has the adeptus mechanicus keyword (excluding agent of the imperium, unaligned, and KNIGHT OF THE COG units) this unit receives xxx." "Knights of the Cog" lets you give the "knights of the cog" keyword to one super heavy AUXILARY detachment (not super heavy detachment), as long as you have included an admech detachment prior to this. Which then makes it eligible for the above 'excludes') Basically this means you can include 1 SHAD per admech detachment, without losing any canticles/imperative on your admech. So yep, including a knight with your battalion should be fine! NOTE - Currently Metallica have a way of including several Raven knights without losing canticles, as long as you use the 'knight of the iron cog' start on every knight pre-battle. Ahh okay thank you DanPesci 1 Back to top Link to comment https://bolterandchainsword.com/topic/370447-knights-of-the-cog/#findComment-5704662 Share on other sites More sharing options...
Magos Takatus Posted January 15, 2022 Share Posted January 15, 2022 Which pool of Stratagems would a Knight of the cog be able to pull from if any? Knights of the Cog seems to be more about not losing benefits for the main Admech detachment rather than giving perks to the auxiliary Knight as well so I'm unsure if they can run around using Imperial Knight Stratagems. Death Grip looks fun but I might need to give up on it. Link to comment https://bolterandchainsword.com/topic/370447-knights-of-the-cog/#findComment-5784497 Share on other sites More sharing options...
Focslain Posted January 18, 2022 Share Posted January 18, 2022 Which pool of Stratagems would a Knight of the cog be able to pull from if any? Knights of the Cog seems to be more about not losing benefits for the main Admech detachment rather than giving perks to the auxiliary Knight as well so I'm unsure if they can run around using Imperial Knight Stratagems. Death Grip looks fun but I might need to give up on it. Any stratagem that is an 'Imperial Knight Stratagem' is available to a Knight of the Cog knight(s). So your good to go for Death Grip, happy squeezing. Magos Takatus 1 Back to top Link to comment https://bolterandchainsword.com/topic/370447-knights-of-the-cog/#findComment-5785817 Share on other sites More sharing options...
Magos Takatus Posted January 18, 2022 Share Posted January 18, 2022 Which pool of Stratagems would a Knight of the cog be able to pull from if any? Knights of the Cog seems to be more about not losing benefits for the main Admech detachment rather than giving perks to the auxiliary Knight as well so I'm unsure if they can run around using Imperial Knight Stratagems. Death Grip looks fun but I might need to give up on it. Any stratagem that is an 'Imperial Knight Stratagem' is available to a Knight of the Cog knight(s). So your good to go for Death Grip, happy squeezing. Haha! Thank you, I will bear that in mind for my rematch! Link to comment https://bolterandchainsword.com/topic/370447-knights-of-the-cog/#findComment-5785905 Share on other sites More sharing options...
