Pointystick11 Posted May 30, 2021 Share Posted May 30, 2021 Hey all, With the release of the new codex I have been inspired to go back and work on some mechanicus models that I hadn't gotten around to painting yet. I've had a hard time settling on a colour scheme for these models, as there's so much going on with every sculpt. However, I do think I want to do something inspired by the borg from Star Trek. I was thinking about trying to experiment by doing green OSL for weapon glows and occular implants. However, there is a LOT of black on Star Trek borg, and I think the scheme would fall flat with too much black. I was wondering if anyone had a suggestion of what I can toss in to add some variety while still remaining true to the idea. So far I can only really see greys and silvers mixing well, but again that seems a bit dull. Any advice would be greatly appreciated! Link to comment https://bolterandchainsword.com/topic/370468-borg-inspired-colour-scheme/ Share on other sites More sharing options...
INKS Posted May 30, 2021 Share Posted May 30, 2021 The trick to black colored armies is highlighting with grey or maybe even a dark blue for the highlights. going flat black isn't going to look too good. maybe even something like stormhost silver might be good. It doesn't have to be too complicated, a simple dry brush. you could even use a really dark green. that might also look good. Pointystick11 1 Back to top Link to comment https://bolterandchainsword.com/topic/370468-borg-inspired-colour-scheme/#findComment-5705171 Share on other sites More sharing options...
NovemberIX Posted May 31, 2021 Share Posted May 31, 2021 I got this piece of advice from a black templars player, but don't use a full black as your base, add in a bit of grey so you can use full black for shadow. A bit of silver flake and some clear medium would let you add a metallic sheen as well for a nice effect. walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/370468-borg-inspired-colour-scheme/#findComment-5705218 Share on other sites More sharing options...
Bjorn Firewalker Posted May 31, 2021 Share Posted May 31, 2021 Use silver to trim the armor, the trimming serving to outline the plates and allow a viewer to visually differentiate them. Without the different colored trimming, the model will visual devolve into a blob. Link to comment https://bolterandchainsword.com/topic/370468-borg-inspired-colour-scheme/#findComment-5705567 Share on other sites More sharing options...
Luku Posted May 31, 2021 Share Posted May 31, 2021 For a good Borg Black: Start with a Corax White base (No, really!) Wash with Contrast Black Templar Wash again with Nuln Oil (Regular or Gloss, your choice) This way you get a black that's dark enough for purpose but you can still see the edges, drybrushing is an optional extra if you want the edges brought out more sharply. Bjorn Firewalker, ValourousHeart and walter h 3 Back to top Link to comment https://bolterandchainsword.com/topic/370468-borg-inspired-colour-scheme/#findComment-5705596 Share on other sites More sharing options...
