davextreme Posted June 3, 2021 Share Posted June 3, 2021 I like how the Primaris Eliminators have little bits of ruins in the kit for glueing onto their bases. I know I could make some with sprue bits and such but I was wondering if anyone know of kits that had these sorts of things pre-made. Link to comment https://bolterandchainsword.com/topic/370541-rubble-kits-for-base-decorating-like-eliminators/ Share on other sites More sharing options...
Commisar Necros Posted June 3, 2021 Share Posted June 3, 2021 I've been looking for something similar, I don't want to base 100 guardsmen individually. From what I've found there are some 3d printed stuff you can get/make but there's usually only like 5 unique bases for a single size. For cobblestone or tiles it can work since they're repetitive, but organic rubble will look weird when there's duplicates in some squads let alone an army. They might have scatter terrain or the like to add in variety though. When I'm building HW squads and want rubble, I've usually used the old sand (irregular not fine) and glue method, then adding in some broken up tank bits. Some might be a little big for the smaller bases, but should be decent for terminator and larger bases. Ive found if you add that to some cut up sprues for girders and the like and you keep a good variety without having to shell out. Link to comment https://bolterandchainsword.com/topic/370541-rubble-kits-for-base-decorating-like-eliminators/#findComment-5706634 Share on other sites More sharing options...
davextreme Posted June 3, 2021 Author Share Posted June 3, 2021 For my Blood Angels I got a rolling pin from Green Stuff World that has a cobblestone pattern. You smush some green stuff onto the base then roll the roller over it and you get a nice pattern. Then I’d just paint them grey and shade them and they looked great. To be clear regarding the rubble, I’m just looking for bits to glue to bases, not entire bases. Link to comment https://bolterandchainsword.com/topic/370541-rubble-kits-for-base-decorating-like-eliminators/#findComment-5706655 Share on other sites More sharing options...
Firedrake Cordova Posted June 3, 2021 Share Posted June 3, 2021 (edited) I'm not aware of any kits (although the various scale model manufacturers will do brick kits, etc), but one approach you could take is to pour out some plaster in a thin sheet, and then shatter it with a hammer (watching out for flying bits), which should give you a reasonable "concrete rubble" texture for not much effort. I'm sure someone will likely sell silicone moulds, too... Edited June 3, 2021 by Firedrake Cordova Link to comment https://bolterandchainsword.com/topic/370541-rubble-kits-for-base-decorating-like-eliminators/#findComment-5706699 Share on other sites More sharing options...
Arkhanist Posted June 3, 2021 Share Posted June 3, 2021 Anvil industries have some nice resin greebles for decorating bases, but delivery times are a bit up in the air at the moment. https://www.anvilindustry.co.uk/Scenic-Base-Rubble https://www.anvilindustry.co.uk/gothic-ruins-scenic-basing-bits https://www.anvilindustry.co.uk/doric-columns-scenic-sprue https://www.anvilindustry.co.uk/Empty-Ammo-Casings Assuming you don't have access to a 3d printer (there's a bunch of gothic ruins terrain and toppers you could cut up for bits) you could always buy pre-printed ones and chop them up manually to make basing bits, e.g. like this one You could of course do the same with GW terrain kits, but that's kinda an expensive option... Firedrake Cordova and Mithrilforge 2 Back to top Link to comment https://bolterandchainsword.com/topic/370541-rubble-kits-for-base-decorating-like-eliminators/#findComment-5706729 Share on other sites More sharing options...
