Thecaveman97 Posted June 5, 2021 Share Posted June 5, 2021 I'm just trying to figure out how people feel about the Valiant at its new Cost. In chapter approved, it received a 20 point decrease to 230 (245 with all upgrades). Using Legacy of Dorn first turn with 4 Las-Talon shots and 4 Multi-Melta Shots, is it worth it? Looking at the math, While within 12" of a Redemptor with a 2+BS from Techmarine and +1 wound from Tank Hunters Stratagem, you're looking at a dead Redemptor around 70% of the time. At 24 inches, its around 50%. This doesn't even count the Ironhail or the Icarus. With a T8 12W profile, Smokescreen (5pt auto launchers) and 3 wounds regenerated a turn, is it worth it? Link to comment https://bolterandchainsword.com/topic/370561-viability-of-the-gladiator-valiant/ Share on other sites More sharing options...
Captain Caine 24th Posted June 17, 2021 Share Posted June 17, 2021 There's something to be said for fast moving melta. Comparatively, things like eradicators may have great math and numbers, but they are a bit slow off the line. Strategic reserves helps on that front. There's the draw back that they don't shoot turn 1 or might not have a good target when they do come on the table. My concern would be if the valiant gets a turn of shooting and then gets charged and destroyed. I think it's got to work with other units to ensure it's not just showing up for one turn of shooting. I might even play it less aggressively (outside of half range) to give me more room to avoid getting charged. In another way, there might be a unit of enemy attack bikes ready to counter the valiant. The valiant is also not a tank to ignore. It can do a huge amount of damage. So there's some value in using it as a distraction--given it's points however, it's an expensive distraction. Available targets could be a concern, but there are really nasty elite units that its guns can fill a dual purpose roll, not just anti-tank. It's new cost helps, how much I can't say. I think it does have value, but deploying it and using it requires finesse. Link to comment https://bolterandchainsword.com/topic/370561-viability-of-the-gladiator-valiant/#findComment-5711959 Share on other sites More sharing options...
Karhedron Posted June 17, 2021 Share Posted June 17, 2021 For almost exactly the same points you can 4 MM Attack bikes who bring similar levels of firepower. The 2 compare pretty evenly in a lot of ways. ABs have 16 wounds between them but only T5 vs 12 at T8 for the Gladiator. ABs are slightly faster but the Gladiator has a smaller footprint. Gladiator degrades but the ABs lose shots as they are killed off. The Gladiator just takes up 1 HS slot whereas 4ABs would be 2 Fast slots The ABs are CORE which is a big advantage but generally only if you have a suitable buffing character with Bike or Jump Pack. Given that Attack Bikes are generally considered competitive, I think the Gladiator is definitely worth a look as it compares decently in a lot of areas. One significant advantage of Bikes is the "Hit and Run Warfare" stratagem which means opponents can't tie them up in combat so easily. Link to comment https://bolterandchainsword.com/topic/370561-viability-of-the-gladiator-valiant/#findComment-5711996 Share on other sites More sharing options...
