This is a patrol and vanguard smashed together
++ Vanguard Detachment -3CP (Necrons) [96 PL, 6CP, 2,000pts] ++
+ Configuration +
Battle Size [12CP]: 3. Strike Force (101-200 Total PL / 1001-2000 Points)
Detachment Command Cost [-3CP]
Dynasty Choice: Dynasty: Novokh
+ HQ +
Chronomancer [4 PL, 90pts]: Entropic Lance
Skorpekh Lord [7 PL, -1CP, 130pts]: Dynastic Heirlooms, Relic: Nanoscarab Casket, Warlord, Warlord Trait (Codex 1): Enduring Will
Technomancer [5 PL, -1CP, 100pts]: Arkana: Phylacterine Hive, Canoptek Cloak, Dynastic Heirlooms, Relic: Voltaic Staff
Technomancer [6 PL, -1CP, 120pts]: Arkana: Fail-Safe Overcharger, Canoptek Control Node, Rarefied Nobility, Relic: Veil of Darkness, Warlord Trait (Codex 4): Thrall of the Silent King
+ Troops +
Immortals [4 PL, 85pts]: Gauss Blaster, 5x Immortal
+ Elites +
Canoptek Spyders [12 PL, 215pts]
. Canoptek Spyder: Gloom Prism, Two Particle Beamers
. Canoptek Spyder: Two Particle Beamers
Skorpekh Destroyers [10 PL, 210pts]
. 2x Skorpekh Destroyer (Reap-Blade): 2x Hyperphase Reap-Blade
. 4x Skorpekh Destroyer (Thresher): 4x Hyperphase Threshers
+ Fast Attack +
Canoptek Scarab Swarms [6 PL, 135pts]
. 9x Canoptek Scarab Swarm: 9x Feeder Mandibles
++ Total: [96 PL, 6CP, 2,000pts] ++
Created with BattleScribe (https://battlescribe.net)
Edited by Gloomfoe
https://bolterandchainsword.com/topic/370603-destroyer-cult-canoptek-cult/
Is this for Narrative play? As you have 4 scarab swarms and Matched Play only allows 3. Maybe replace one of the scarab units with some Flayed Ones or Canoptek Wraiths?
Anyway, it looks like a fun list, but any rational opponent will take the new No Prisoners to max out VPs with the multi-Wound units you have. You should have a fairly fast-moving army that can tie up the enemy and then destroy them in melee.
You’ve also got too many hqs, as both detachments cap at 2, and you have no Noble character for the Dynastic Advisor rule.
I’d use your spare points for something to sit on objectives. I’d say lychguard or warriors, but, sticking with the Canoptek/destroyer theme I’d suggest wraiths.
You could also add heavy Lokhust destroyers for some theme appropriate long range firepower.
Ok, took another pass at it. Remember, this is a patrol and vanguard smashed together. Funnily, I couldn't find room for the skorpek destroyer lord even in a destroyer themed army. Added a plasmancer and 20 flayed ones for leadership shenanigans.
++ Vanguard Detachment -3CP (Necrons) [96 PL, 8CP, 2,000pts] ++
+ Configuration +
+ HQ +
Psychomancer [5 PL, 95pts]: Arkana: Atavindicator, Relic: Veil of Darkness
Technomancer [6 PL, -1CP, 120pts]: Arkana: Fail-Safe Overcharger, Canoptek Control Node, Rarefied Nobility, Warlord Trait (Codex 4): Thrall of the Silent King
Trazyn the Infinite [5 PL, 100pts]
+ Troops +
+ Elites +
Flayed Ones [12 PL, 260pts]
. 20x Flayed One: 20x Flayer Claws
+ Fast Attack +
++ Total: [96 PL, 8CP, 2,000pts] ++
Register a new account
Sign in
