Skywrath Posted June 11, 2021 Share Posted June 11, 2021 Planning on kit-bashing an Interrogator-Chaplain in TDA, have all the bits except for the back. Seeing how eBay is fresh out of the DA backs and I don't want to pay 80AUD for another fresh box, below my options. I ask whether I can use backs from other non DA kits and whether they will work on this DA robe? Can't use greenstuff (as I'm fresh out), so I'm aiming for a seamless fit from the start. Robe link: https://www.ebay.com.au/itm/402864404513 Torso: SW one: https://www.ebay.com.au/itm/254427779161 Chaos one: https://www.ebay.com.au/itm/393025584726 (If all goes well, this is the ideal candidate) because of the trim. Generic one: https://www.ebay.com.au/itm/284293494063 Link to comment https://bolterandchainsword.com/topic/370642-terminator-back-compatibility/ Share on other sites More sharing options...
painting.for.my.sanity Posted June 11, 2021 Share Posted June 11, 2021 (edited) DA fronts are compatible with generic backs - https://www.instagram.com/p/COkGzPDHczO/, and generic fronts are compatible with DA backs - https://www.instagram.com/p/COmy1Wwn8fb/ Edited June 11, 2021 by SufficientAnonymity LameBeard and Skywrath 2 Back to top Link to comment https://bolterandchainsword.com/topic/370642-terminator-back-compatibility/#findComment-5709318 Share on other sites More sharing options...
Skywrath Posted June 11, 2021 Author Share Posted June 11, 2021 DA fronts are compatible with generic backs - https://www.instagram.com/p/COkGzPDHczO/, and generic fronts are compatible with DA backs - https://www.instagram.com/p/COmy1Wwn8fb/ What about chaos ones? That trim would look gorgeous if it worked. Link to comment https://bolterandchainsword.com/topic/370642-terminator-back-compatibility/#findComment-5709319 Share on other sites More sharing options...
painting.for.my.sanity Posted June 11, 2021 Share Posted June 11, 2021 DA fronts are compatible with generic backs - https://www.instagram.com/p/COkGzPDHczO/, and generic fronts are compatible with DA backs - https://www.instagram.com/p/COmy1Wwn8fb/ What about chaos ones? That trim would look gorgeous if it worked. I'm afraid I've only tested DA/generic interoperability. I've also successfully mated generic fronts onto GK backs by cutting down the arch over the top of the head - https://www.instagram.com/p/CO3EWuHHHeF/ Skywrath 1 Back to top Link to comment https://bolterandchainsword.com/topic/370642-terminator-back-compatibility/#findComment-5709329 Share on other sites More sharing options...
Sword Brother Adelard Posted June 17, 2021 Share Posted June 17, 2021 I think some of my DA fronts have chaos backs, but I didn't build them, so can't say if it wasn't done with some filing and cutting. But you're right, the trim is awesome. Link to comment https://bolterandchainsword.com/topic/370642-terminator-back-compatibility/#findComment-5711854 Share on other sites More sharing options...
