Arbiter7 Posted June 12, 2021 Share Posted June 12, 2021 Imotekh Stormlord to refund some CP from fielding the monolith. Chronomancer gives it 5++ HQ Imotekh Chronomancer with Obfuscatron Technomancer with Cloak Troops: 20 Warriors Gauss 20 Warriors Flayer 5 Immortals Elites: 2Cryptothralls 10 Lychguard Fast Attack 5 Scarabs 5 Scarabs Heavy: Doomstalker Doomstalker LoW Monolith clocks at 2k to the dot. Link to comment https://bolterandchainsword.com/topic/370660-monolith-fun-2k/ Share on other sites More sharing options...
Daimyo-Phaeron Lenoch Posted June 12, 2021 Share Posted June 12, 2021 The Chronomancer's aura would also give the monolith a reroll to charges, and with it's vacuum that's not insignificant.... I'm guessing your warriors are split 20 and 20 flayer and reaper? Since 'gauss' is appended to both names. Are you planning to use the scarabs for screening or for objective sitting? Link to comment https://bolterandchainsword.com/topic/370660-monolith-fun-2k/#findComment-5709806 Share on other sites More sharing options...
Arbiter7 Posted June 12, 2021 Author Share Posted June 12, 2021 (edited) Are you planning to use the scarabs for screening or for objective sitting? Either I guess ! Any ideas on Relic? Maybe Veil on the chronomancer? I meant Reaper & Flayer - got 20 of each atm...! P.S. I'm just trying to find an excuse to buy a Monolith Edited June 12, 2021 by Arbiter7 Link to comment https://bolterandchainsword.com/topic/370660-monolith-fun-2k/#findComment-5709822 Share on other sites More sharing options...
Daimyo-Phaeron Lenoch Posted June 13, 2021 Share Posted June 13, 2021 Yeah, I think the veil or maybe a defensive relic on the technomancer is your best bet, unless you want to give the chronomancer the gauntlet of fire for some burnination shenanigans if you're trying to drive the monolith up the board, then the chronomancer will have to keep up with him anyway. Link to comment https://bolterandchainsword.com/topic/370660-monolith-fun-2k/#findComment-5710028 Share on other sites More sharing options...
