dice4thedicegod Posted June 27, 2021 Share Posted June 27, 2021 Well, warhound titan anyway:) Think it makes it a bit more dragster and less go kart. Ryltar Thamior, space wolf, Beaky Brigade and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/370841-titanic-invader-atv-conversion/ Share on other sites More sharing options...
Grotsmasha Posted June 27, 2021 Share Posted June 27, 2021 Ditch the crew, and you've made the Batmobile... Skywrath and space wolf 2 Back to top Link to comment https://bolterandchainsword.com/topic/370841-titanic-invader-atv-conversion/#findComment-5714749 Share on other sites More sharing options...
dice4thedicegod Posted June 28, 2021 Author Share Posted June 28, 2021 Ah, If I could 3d print bat symbols, I’d play batwing instead of ravenwing! space wolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/370841-titanic-invader-atv-conversion/#findComment-5714768 Share on other sites More sharing options...
Bjorn Firewalker Posted June 28, 2021 Share Posted June 28, 2021 The storm bolter is mounted too low; dirt, mud, and other roadside debris will plug up the muzzles as the ATV moves, damaging the weapon. If you want to keep the storm bolter where it's at, replace the wheels with lift fans so the model can serve as a Land Speeder or Storm Speeder. Link to comment https://bolterandchainsword.com/topic/370841-titanic-invader-atv-conversion/#findComment-5714780 Share on other sites More sharing options...
