Valkyrion Posted July 4, 2021 Share Posted July 4, 2021 Following on from a recent ghostly discussion I thought I'd give it a go using blue rather than green so I'm now fishing for opinions (thanks to Lord Marshal for his pic advice!) I'm not sure that it looks ghostly as much as just pale blue so I should paint the gun and metal areas as though they were metal. Beaky Brigade, INKS, Khulu and 8 others 10 1 Back to top Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/ Share on other sites More sharing options...
INKS Posted July 4, 2021 Share Posted July 4, 2021 unless the guns are also ghostly? looks good. Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5716581 Share on other sites More sharing options...
Firedrake Cordova Posted July 4, 2021 Share Posted July 4, 2021 It looks like a good start. :) Have you considered lightening the eyes up a bit? The dark red works as a good contrast, but it might benefit from being a bit lighter? (also, I don't know if it's worth using a Contrast paint if you haven't as these can allow you to get a bit of detail into the eye, instead of it being a flat tone) I do think that it will look quite different once the base has been done. :) LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5716590 Share on other sites More sharing options...
jaxom Posted July 5, 2021 Share Posted July 5, 2021 I agree that making the gun match the rest would be good. Making the red less dark would help. I'd also make the runes in the bolter red. For both eyes and runes, you can use a red shade to make the area around them "glow" and I think you could tease the "glow" upward to make it look more like flickering ghostlight flames. Tipper 1 Back to top Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5716884 Share on other sites More sharing options...
INKS Posted July 5, 2021 Share Posted July 5, 2021 The more I look at them the more I like the idea of "Frozen Sons" I know that isn't what you were going for, it's the blue I guess. Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5716913 Share on other sites More sharing options...
Kierdale Posted July 6, 2021 Share Posted July 6, 2021 I like it! I agree with the comments that a lighter red would be even better. How did you paint it? Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5717163 Share on other sites More sharing options...
Valkyrion Posted July 6, 2021 Author Share Posted July 6, 2021 I like it! I agree with the comments that a lighter red would be even better. How did you paint it? White spray undercoat, aethermantic blue straight from the pot then a heavy drybrush of corax white. I've tried a venomstalker today but it doesn't work well on that so I doubt it would work well on forgefiends. Heldrake might be okay as it's flatter, but I don't think it would work on organic models like possessed/obliterators either. A Lord of Change could look pretty good. Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5717248 Share on other sites More sharing options...
Valkyrion Posted July 6, 2021 Author Share Posted July 6, 2021 Tipper, Dr_Ruminahui, Trokair and 2 others 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5717250 Share on other sites More sharing options...
jaxom Posted July 6, 2021 Share Posted July 6, 2021 I'd try cutting the aethermatic blue with contrast medium when you use it on the large, flat surfaces. There's not enough texture to bring the color up with the white drybrush unless you start with less pigment. Firedrake Cordova and INKS 2 Back to top Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5717269 Share on other sites More sharing options...
LameBeard Posted July 8, 2021 Share Posted July 8, 2021 I think the venom crawler looks ace and the thousand son reads as a ‘ghost’ - I’d even be tempted to keep the red just to eyes and drop the jewels. You can try sponging instead of dry brushing onto the large flat surfaces. This will look amazing once based and as an army together. And is also a beautiful way of tying together the astartes and the daemons. More please! Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5717644 Share on other sites More sharing options...
Wulf Vengis Posted August 17, 2021 Share Posted August 17, 2021 There are a very cool and unique color scheme. I likey. Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5731687 Share on other sites More sharing options...
Rik Lightstar Posted August 17, 2021 Share Posted August 17, 2021 I think they're looking really good. I agree with the others about a brighter red for the eyes, and maybe go for a green on the gems instead of red, it'll make the eyes stand out more. Biggest step next is to choose how to base them, that'll really determine the impact. I'd recommend either a deep desert ochre or a reddish brown mud. Do either with a little bit of greenery on each base and then a light drybrush of black on the side(s) nearest the the miniature to show that the evil ghostiness is killing the plants. Rik Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5731798 Share on other sites More sharing options...
Xenith Posted August 18, 2021 Share Posted August 18, 2021 Awesome, consider a brighter red, maybe even an orange (complimentary to the blue) for the eyes, if you want them firey - otherwise the normal ghostly glowy green would work to keep them cold looking. Do you mind if I add this scheme to my index of alternative (easier to paint) Thousand sons schemes? http://www.bolterandchainsword.com/topic/371208-thousand-sons-alternative-paint-scheme-inspiration-thread/ Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5731947 Share on other sites More sharing options...
Grotsmasha Posted August 18, 2021 Share Posted August 18, 2021 I really like this scheme, and I wouldn't worry about the Crawler, it looks aces :tu: Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5731950 Share on other sites More sharing options...
Valkyrion Posted August 18, 2021 Author Share Posted August 18, 2021 Awesome, consider a brighter red, maybe even an orange (complimentary to the blue) for the eyes, if you want them firey - otherwise the normal ghostly glowy green would work to keep them cold looking. Do you mind if I add this scheme to my index of alternative (easier to paint) Thousand sons schemes? http://www.bolterandchainsword.com/topic/371208-thousand-sons-alternative-paint-scheme-inspiration-thread/ Of course you can! I'd actually abandoned this project but you lot have made me consider reopening - amazing what the words of strangers on the internet can do! Firedrake Cordova, LameBeard and Grotsmasha 3 Back to top Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5731988 Share on other sites More sharing options...
Brother Dumnorix Posted September 2, 2023 Share Posted September 2, 2023 Hey this is so nice! I've decided to run a quick and dirty test model and im impressed how nice it looks and how easy it is to do, I have still to tweak it to look more like the one you did but I think im in the right path! Im tempted now to do a full ghostly Thousand Sons force leaving the sorcerers full painted and the dusty brothers ghostly I've used the same paints as you except for the drybrush, that is white scar instead of corax white Thanks again for sharing with us your cool take on the scheme! jaxom, Xenith, LameBeard and 1 other 3 1 Back to top Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5985541 Share on other sites More sharing options...
The Praetorian of Inwit Posted September 5, 2023 Share Posted September 5, 2023 That looks like a pretty darn good scheme to me. Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5986389 Share on other sites More sharing options...
Brother Dumnorix Posted September 19, 2023 Share Posted September 19, 2023 (edited) Decided to do a little retro squad using the scheme + magmadroth flame contrast. Thanks again for the inspiration!! Edited September 19, 2023 by Brother Dumnorix LameBeard, Firedrake Cordova, Dr_Ruminahui and 3 others 3 3 Back to top Link to comment https://bolterandchainsword.com/topic/370901-ghost-thousand-sons-test-scheme/#findComment-5989852 Share on other sites More sharing options...
