Brother, you've made my life soooooo much easier! Thank you!
Just be careful, those images are a bit of a trap in making the heads seem a similar size - the contemptor head is actually much larger, and I've seen them use to good effect in giving Primarch models helmets.
For your info, here's what a normal marine head in a contemptor chassis looks like:
Clearly smaller than the original head was, which extended another ~1-2mm on either side.
Register a new account
Sign in
