Inquisitor_Lensoven Posted July 14, 2021 Share Posted July 14, 2021 Assuming the don't die fighting, what's an old ork, what's an average aged ork at natural death? Link to comment https://bolterandchainsword.com/topic/370988-old-do-orks-typically-get/ Share on other sites More sharing options...
Charlo Posted July 14, 2021 Share Posted July 14, 2021 Numerical age isn't something that's defined for the Orks. It's certainly something they don't care about! However, obviously they get bigger the longer they stay alive fighting. As for a natural death? I genuinely don't think they happen. The longer an Ork fights the stronger he gets! Link to comment https://bolterandchainsword.com/topic/370988-old-do-orks-typically-get/#findComment-5719801 Share on other sites More sharing options...
Brother Sergeant Tiberius Posted July 14, 2021 Share Posted July 14, 2021 Closest thing to a natural death was I think one of those biologist reports in the back of the old 4/5th Ed dex? Where if an ork is isolated from others of its kind it kinda withers and dies. Other than that it's death by fighting or misadventure Link to comment https://bolterandchainsword.com/topic/370988-old-do-orks-typically-get/#findComment-5719803 Share on other sites More sharing options...
tentagil Posted July 20, 2021 Share Posted July 20, 2021 So Ghazghkull Mag Uruk Thraka first shows up in Imperial records around 932.M41 and in the current game lore its around the year 111.M42 and he is known to still be active. So that gives him a life span of at least 179 years. Though its likley he's quite a bit older since he wouldn't have been known to the Imperium until he became at least a Warboss, which would mean working his way up the ranks. So you can assume he's at least 200+ and seems to be in his prime. I'd make a guess that since Orks and Eldar have the same creators, and the old ones were essentially immortal, Orks likely have natural life spans in the thousands of years, but most die in combat long before that. Dumah and Kheotour 2 Back to top Link to comment https://bolterandchainsword.com/topic/370988-old-do-orks-typically-get/#findComment-5721844 Share on other sites More sharing options...
Perry Posted July 22, 2021 Share Posted July 22, 2021 So Ghazghkull Mag Uruk Thraka first shows up in Imperial records around 932.M41 and in the current game lore its around the year 111.M42 and he is known to still be active. So that gives him a life span of at least 179 years. Though its likley he's quite a bit older since he wouldn't have been known to the Imperium until he became at least a Warboss, which would mean working his way up the ranks. So you can assume he's at least 200+ and seems to be in his prime. I'd make a guess that since Orks and Eldar have the same creators, and the old ones were essentially immortal, Orks likely have natural life spans in the thousands of years, but most die in combat long before that. He's had his fair share of traveling through the Warp, that can play havoc with your birthdays. Link to comment https://bolterandchainsword.com/topic/370988-old-do-orks-typically-get/#findComment-5722480 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 26, 2021 Author Share Posted July 26, 2021 Confirmed grots can die of old age https://m.youtube.com/watch?v=tJ5K5Yk6L6A Link to comment https://bolterandchainsword.com/topic/370988-old-do-orks-typically-get/#findComment-5723381 Share on other sites More sharing options...
