XeonDragon Posted July 15, 2021 Share Posted July 15, 2021 So, this has come up in a few league games recently.... auras. Say a chaplain recites a litany, there are 2 units in range. If he then zooms away, do they get the benefit of the litany? Conversely, if he recites a litany away from models, then zooms up and two units are now within the aura range, do they then get it? Same applies for librarians and apothecaries, e.g. psychic fortress, cast it, give 5++ to models nearby, but if you move away from them, or models move inside the aura radius do they lose/get it? Link to comment https://bolterandchainsword.com/topic/371002-question-about-auras-generally/ Share on other sites More sharing options...
BluejayJunior Posted July 16, 2021 Share Posted July 16, 2021 It depends on the litany. If it's marked as an aura, then it only affects units within the range of the chaplain. So if it moves after reciting the litany, it only affects units around its current location. If it isn't an aura, you pick a model/unit within the range of the chaplain when it's recited and then they gain that affect even if the chaplain then moves away. Auras create a zone of effect around the model, so you have to be in that zone of effect to gain the benefits. The aura moves with the model. BLACK BLŒ FLY and XeonDragon 2 Back to top Link to comment https://bolterandchainsword.com/topic/371002-question-about-auras-generally/#findComment-5720528 Share on other sites More sharing options...
Lord Raven 19 Posted July 16, 2021 Share Posted July 16, 2021 Yes, an aura works moves with it's bearer. Think of it like a wifi access point, if you move away, or it is moved away from you, you lose access to the wifi. The psychic power and litany roll could be seen as (continuing the wifi analogy) turning the hotspot on and it automatically turning off after an hour (or a battle round). Does that help? XeonDragon 1 Back to top Link to comment https://bolterandchainsword.com/topic/371002-question-about-auras-generally/#findComment-5720595 Share on other sites More sharing options...
XeonDragon Posted July 18, 2021 Author Share Posted July 18, 2021 Thanks all, that was very helpful. Next time a mate of mine tries to cast psychic fortress on a blob of 7 aggressor and then moves, advances and charges them into me whilst the librarian moves to another location, I'll know the 5++ ain't happening anymore :D Karhedron and BLACK BLŒ FLY 2 Back to top Link to comment https://bolterandchainsword.com/topic/371002-question-about-auras-generally/#findComment-5721259 Share on other sites More sharing options...
Kallas Posted July 19, 2021 Share Posted July 19, 2021 Thanks all, that was very helpful. Next time a mate of mine tries to cast psychic fortress on a blob of 7 aggressor and then moves, advances and charges them into me whilst the librarian moves to another location, I'll know the 5++ ain't happening anymore Yup, that's how Psychic Fortress works. Just to be clear, it's worth noting that some Litanies/Psychic Powers are applied at the time of recitation of the litany (eg, Catechism of Fire)/manifestation of the power (eg, Might of Heroes), where the reciter/caster can move away and the initial units are affected (and new units nearby are not). XeonDragon and Lord Raven 19 2 Back to top Link to comment https://bolterandchainsword.com/topic/371002-question-about-auras-generally/#findComment-5721597 Share on other sites More sharing options...
Xenith Posted July 21, 2021 Share Posted July 21, 2021 Thanks all, that was very helpful. Next time a mate of mine tries to cast psychic fortress on a blob of 7 aggressor and then moves, advances and charges them into me whilst the librarian moves to another location, I'll know the 5++ ain't happening anymore If he tried that, then he either hasn't read the rule or is cheating. PsyFort gives models within 5" of the librarian a 5+ invuln. If a model isn't within 6" then no invuln. How is a fortress supposed to protect you if you leave it? Contrast this with powers like Shield of Sanguinius, which says "pick a unit within 18", that unit gains a 5+ invuln". That kind of rule sticks with the unit. Lord Raven 19 and XeonDragon 2 Back to top Link to comment https://bolterandchainsword.com/topic/371002-question-about-auras-generally/#findComment-5721997 Share on other sites More sharing options...
