Valkyrion Posted July 20, 2021 Share Posted July 20, 2021 Have I caused my spray to go bad by either incorrect storage or not shaking enough? If not, is the whole can going to be chalky or is there something I can do to unchalkify it? Link to comment https://bolterandchainsword.com/topic/371038-chalky-white-spray/ Share on other sites More sharing options...
Grotsmasha Posted July 20, 2021 Share Posted July 20, 2021 (edited) GW's Corax White spray is , use either of their contrast sprays, they are miles better. With that out of the way, there are a few things you can do to help prevent chalky sprays - Shike for like 2 mins solid, I even flip the can, no idea if it helps, but it doesn't hurt - Don't spray in direct sunlight, this can cause the paint to dry in the air, causing the chalky-ness - Don't spray from too far away, as same as above. Typically I spray a little closer that GW recommends with their sprays - Humidity causes issues too. The paint in the can should be fine to use, it doesn't go off, as far as I've experienced at least. Taking the above into consideration, try to spray in a shaded area, in the cool of the morning or afternoon in summer, or once it's warmer, late morning, early afternoon in winter. IIRC GW recommends like 2 feet? I'm usually around 1 foot, maybe a smidge less. And remember two medium paced, smooth passes, 2-3 per side of the model, rather than one slow thick pass. Edited July 20, 2021 by Grotsmasha Trokair and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/371038-chalky-white-spray/#findComment-5721696 Share on other sites More sharing options...
Xenith Posted July 20, 2021 Share Posted July 20, 2021 (edited) In general, 'white' sprays are tricky as they need coarser pigment particles. As Grotsmasha says, it's likely the paint is drying in the air before it hits the model, making it fuzzy/chalky. I prime from ~20cm, not the 30 GW says, and not on hot days/direct sunlight. I can't reccomend grey seer enough - it's much finer, bit thinner so needs a few coats, but weirdly, it's brighter than the grey seer pot paint. Grey seer spray is actually identical to corax white (actually a grey) pot paint, so that might help. Edited July 20, 2021 by Xenith Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/371038-chalky-white-spray/#findComment-5721699 Share on other sites More sharing options...
Firedrake Cordova Posted July 20, 2021 Share Posted July 20, 2021 As has been said, the normal cause for a rough finish is the paint drying before it reaches the model. This is more apparent with white paint, because it normally uses titanium oxide for pigment, which is (relatively) fairly coarse. This generally means: Spray from a shorter distance Make sure you've shaken then can enough. When you think you have, shake it some more :P If it's cold, stand the spray can in warm water for a while to heat the contents up before shaking it Make sure the humidity isn't too low. As always, employ good spray practice (start spraying "off the model", bring the spray over the model, stop spraying "off" the model; use light coats). Some people have had issues with GW's spray cans, and prefer Army Painter/Rustoleum/Halford's car paint. I can't comment on these, as I've not used them (I went the airbrush route). Link to comment https://bolterandchainsword.com/topic/371038-chalky-white-spray/#findComment-5721735 Share on other sites More sharing options...
Jason_In_Alaska Posted July 22, 2021 Share Posted July 22, 2021 Molotow One4All Signal White, and Signal Black through a airbrush is what I have been using for primer and I will never go back to traditional primer. Link to comment https://bolterandchainsword.com/topic/371038-chalky-white-spray/#findComment-5722399 Share on other sites More sharing options...
Mithrilforge Posted July 22, 2021 Share Posted July 22, 2021 (edited) I stand the can of Corax white in a sink of very warm (hot) water for 5-10 mins then shake it up and spray... smooth as a baby's proverbial... I too had the chalkiness from Corax white spray for years before i did this. Mithril Edited July 22, 2021 by mithrilforge Firedrake Cordova and NTaW 2 Back to top Link to comment https://bolterandchainsword.com/topic/371038-chalky-white-spray/#findComment-5722402 Share on other sites More sharing options...
Valkyrion Posted July 22, 2021 Author Share Posted July 22, 2021 Thanks for the replies. is there anything to be done about the minis that have ended up chalky though? Will a respray remove it? Link to comment https://bolterandchainsword.com/topic/371038-chalky-white-spray/#findComment-5722450 Share on other sites More sharing options...
Grotsmasha Posted July 22, 2021 Share Posted July 22, 2021 Thanks for the replies. is there anything to be done about the minis that have ended up chalky though? Will a respray remove it? Sadly, no, the only way to recover them is to strip the paint. Link to comment https://bolterandchainsword.com/topic/371038-chalky-white-spray/#findComment-5722492 Share on other sites More sharing options...
Rik Lightstar Posted July 22, 2021 Share Posted July 22, 2021 Thanks for the replies. is there anything to be done about the minis that have ended up chalky though? Will a respray remove it? Often a quick bit of attention with a toothbrush will get the furry/chalkiness off, a light solvent such as airbrush cleaner may help. If that doesn't work then BioStrip 20 is a great product. Rik Link to comment https://bolterandchainsword.com/topic/371038-chalky-white-spray/#findComment-5722500 Share on other sites More sharing options...
Mithrilforge Posted July 22, 2021 Share Posted July 22, 2021 Thanks for the replies. is there anything to be done about the minis that have ended up chalky though? Will a respray remove it? also, i found some light buffing work with a polishing cloth can help smooth down the chalkiness as well, it'll take some firm but consistent rubbing work, but i'd reserve that for say an expensive character or model you really really want to save Mithril Link to comment https://bolterandchainsword.com/topic/371038-chalky-white-spray/#findComment-5722711 Share on other sites More sharing options...
Wulf Vengis Posted August 17, 2021 Share Posted August 17, 2021 I can vouch for the toothbrush method. A minute or two of rub down with a toothbrush will take care of that fuzzy/rough feeling. I had to brush all the orks after priming last summer. Rik Lightstar 1 Back to top Link to comment https://bolterandchainsword.com/topic/371038-chalky-white-spray/#findComment-5731684 Share on other sites More sharing options...
