greatcrusade08 Posted July 20, 2021 Share Posted July 20, 2021 Hi guys as the title suggests, if im running a dual batallion, and want to run different doctrines (taken from custom choices) for each. how do i get away with this on the tabletop wihout painting them differently? Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/ Share on other sites More sharing options...
Lord Raven 19 Posted July 20, 2021 Share Posted July 20, 2021 For a GW tourney, I think they need to be painted differently, or be different models, i.e cadian models for one and catachan for the other. I think it would be fair, for a unified force that it is easy for the opponent to tell what's what, to use a vehicle detachment (only vehicle and regimental advisors) as one, and infantry as the other. Not sure how I'd do two different infantry detachments painted the same, doesn't seem fair on the opponent to make them have to distinguish between them. Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5721822 Share on other sites More sharing options...
greatcrusade08 Posted July 20, 2021 Author Share Posted July 20, 2021 yeah i was thinking similar, have chimera borne infantry with a different loudout in one detahcment and have foot guard in a second so you an easily destinguish between them walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5721829 Share on other sites More sharing options...
tychobi Posted July 20, 2021 Share Posted July 20, 2021 If I can't recognize what is what from 3m at a glance you have a problem. Colored movement trays? Even then if I get confused about what is what and it costs me 5 seconds to figure it out in a timed match you have gained an unfair advantage. walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5721833 Share on other sites More sharing options...
greatcrusade08 Posted July 20, 2021 Author Share Posted July 20, 2021 would a coloured stripe on shoulder pad work you think? Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5721851 Share on other sites More sharing options...
sairence Posted July 20, 2021 Share Posted July 20, 2021 Don't think that would be obvious enough. It really must be clear at a glance. Some small details won't do that, you need to have some pretty obvious differences. jarms48, walter h and Lord Raven 19 3 Back to top Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5721864 Share on other sites More sharing options...
greatcrusade08 Posted July 20, 2021 Author Share Posted July 20, 2021 damn, oh well, thanks guys Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5721870 Share on other sites More sharing options...
4ndroid Posted July 20, 2021 Share Posted July 20, 2021 might be tricky for infantry or hordes split between two doctrine as mentioned I've been working on a list where all my calvary are Krieg, all my Infantry are Catachan pretty simple for both tournaments and friendlies try splitting up the units as needed Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5721923 Share on other sites More sharing options...
jarms48 Posted July 21, 2021 Share Posted July 21, 2021 would a coloured stripe on shoulder pad work you think? Could do it old school white shield style. Put different colour stripes down the middle of the helmet. Detachment 1 has a single blue stripe, detachment 2 has a single red stripe. greatcrusade08 1 Back to top Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5721975 Share on other sites More sharing options...
duz_ Posted July 21, 2021 Share Posted July 21, 2021 I'm not sure a stripe on the model would be sufficient. A different coloured base rings would be more obvious. Also depends is this for casual or competitive. If it's the former check with your opponent if it's the latter it's gonna be a lot tougher. Especially if you're trying to distinguish infantry. Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5722117 Share on other sites More sharing options...
sairence Posted July 21, 2021 Share Posted July 21, 2021 (edited) So I ll give an example of my own dudes that I find sufficient. I have most of my Cadians painted up in my actual colour scheme. Grey-blueish fatigues, black boots, metallic black armour, purple guns. Then I have about 30 more Cadians, that are in the traditional Green/Brown paint scheme. I basically left them as they were after I got them from ebay. This way, if I want to run Guardsmen in a second detachment I have a completely different look for the same type of model. There's no way you can look at both paint schemes and think they're the same. Personally, that's the level of difference I would find acceptable for running different detachments. But if I have to search for the small details that set them apart that's not enough. It's enough to separate Conscripts/Guardsmen/Vets, but not entire regiments. The alternative that I often go for is to fill my second detachment's troop slots with small barebones Scion squads. Often that'll be in a patrol or a spearhead with my armoured units. Edited July 21, 2021 by sairence duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5722190 Share on other sites More sharing options...
greatcrusade08 Posted July 21, 2021 Author Share Posted July 21, 2021 all of my guardsmen have berets, if i painted the berets and shoulder pads a different colour, would it be appropriate for competitive games? Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5722265 Share on other sites More sharing options...
duz_ Posted July 21, 2021 Share Posted July 21, 2021 Possibly If there's a particular event you want to attend or a TO on your area that usually hosts games I'd check with them first. Maybe do a test model so you can show them side by side. greatcrusade08 1 Back to top Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5722286 Share on other sites More sharing options...
greatcrusade08 Posted July 21, 2021 Author Share Posted July 21, 2021 Thank you, its really hard to find the line of acceptability in the grey here. i dont want to paint my models differently as ive only got a limited amount, but want to be able to use the different rules (for advantage). i dont mind a small deviation, bu core colours i want to be the same, i guess worst case is i dont use different rules Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5722288 Share on other sites More sharing options...
duz_ Posted July 21, 2021 Share Posted July 21, 2021 That's why it's always best to check with your TO walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5722305 Share on other sites More sharing options...
jarms48 Posted July 21, 2021 Share Posted July 21, 2021 I'm not sure a stripe on the model would be sufficient. A different coloured base rings would be more obvious. Also depends is this for casual or competitive. If it's the former check with your opponent if it's the latter it's gonna be a lot tougher. Especially if you're trying to distinguish infantry. I don't know, I think you could get away with painting vibrant bright colours as stripes. White, Yellow, Red, just tell your opponent White is Detachment 1 and Red is Detachment 2, etc. You could also paint the skull aquilas the same colour as the stripe as well. Warhead01 and brother_b 2 Back to top Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5722363 Share on other sites More sharing options...
MedicMike0708 Posted July 22, 2021 Share Posted July 22, 2021 Not that it would be ideal, but entirely different basing coupled with the minor details such as shoulder pads and or striping would likely be more acceptable, but it would have to be widely different; forest/agriworld and urban rubble or deck plating or volcanic for example. walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/371041-running-dual-batallions-with-different-doctrines/#findComment-5722522 Share on other sites More sharing options...
