Brother Syddraf Posted July 22, 2021 Share Posted July 22, 2021 Hi all, Has anyone found numbers, 3d printed or decal that goes from 1 to 20, but small enough to fit on the small square section of the winged sword banner that comes with the veterans box. All my greening squads are using these banners and it would top them off nicely with a squad number on them as well. Any ideas, thanks Link to comment https://bolterandchainsword.com/topic/371057-numbers-for-dark-angel-banners/ Share on other sites More sharing options...
Brother Tyler Posted July 22, 2021 Share Posted July 22, 2021 Did you check to see if any of the decals in our Downloads section work? Blackletter Numerals Gothic Numbers v2 Roman Numerals Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/371057-numbers-for-dark-angel-banners/#findComment-5722545 Share on other sites More sharing options...
ValourousHeart Posted July 22, 2021 Share Posted July 22, 2021 You might look for tiny brass numbers from stores that sell items for Doll Houses. They make tons of tiny details for them. There are also ebay sellers that make brass sheets of icons for 40k, if you contact one of them, they can custom make a sheet for you of exactly what you want. Link to comment https://bolterandchainsword.com/topic/371057-numbers-for-dark-angel-banners/#findComment-5722664 Share on other sites More sharing options...
Brother Syddraf Posted July 23, 2021 Author Share Posted July 23, 2021 The ones in the download section would be perfect but I need up to 20 and they only go to 10 Link to comment https://bolterandchainsword.com/topic/371057-numbers-for-dark-angel-banners/#findComment-5722763 Share on other sites More sharing options...
ValourousHeart Posted July 25, 2021 Share Posted July 25, 2021 (edited) Just curious why you are looking for up to 1-20 instead of 1-10? Are you not able to edit the image? Alternatively if you are just trying to distinguish between the combat squad the sergeant goes into and the one that the "counts as sergeant" goes into you can just use an alternative background color. So for example everyone is green, they you paint the company number on one kneepad. On the other kneepad goes the squads 1-10 with a white/bone back ground and a second set 1-10 with a black background. Maybe match that color with the top plate on the back pack and possibly the number as well, so that both you and your opponent can tell no matter which way the model is facing. Edited July 25, 2021 by ValourousHeart Link to comment https://bolterandchainsword.com/topic/371057-numbers-for-dark-angel-banners/#findComment-5723371 Share on other sites More sharing options...
Brother Syddraf Posted July 29, 2021 Author Share Posted July 29, 2021 All of my primaris squads are in squads of 5, just so there was a different look to my primaris companies vs firstborn. I tried sanding down a shoulder icon from Plokoone's Bits off shapeways but is hard due to the tiny size Might try editing the decal file and see if I can make it 1 to 20 and look as good as the original file Link to comment https://bolterandchainsword.com/topic/371057-numbers-for-dark-angel-banners/#findComment-5724691 Share on other sites More sharing options...
ValourousHeart Posted July 30, 2021 Share Posted July 30, 2021 Alternatively if you are just trying to distinguish between the combat squad the sergeant goes into and the one that the "counts as sergeant" goes into you can just use an alternative background color. All of my primaris squads are in squads of 5, just so there was a different look to my primaris companies vs firstborn. Yeah I figured, which is why I was teasing you about it. Link to comment https://bolterandchainsword.com/topic/371057-numbers-for-dark-angel-banners/#findComment-5724840 Share on other sites More sharing options...
