Montuhotep Posted August 15, 2021 Share Posted August 15, 2021 Okay folks, simple enough question for those who have replaced Abby's Talon with something else. What arm do you use? For size purposes, that is? I thought of a regular Termi arm but on the other hand it doesn't seem to have the bulk required to match the new Abby now he's been upscaled somewhat. Then I saw the Inceptor arms, particularly the plasma one. Would this be better? Link to comment https://bolterandchainsword.com/topic/371289-converting-abbaddon/ Share on other sites More sharing options...
Tichinde Posted August 15, 2021 Share Posted August 15, 2021 (edited) I opted for a forge world primarch arm. It's a little bigger but works. I'll get a pic shortly. Edited August 15, 2021 by Tichinde Prot, Khornestar, LameBeard and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/371289-converting-abbaddon/#findComment-5730784 Share on other sites More sharing options...
Prot Posted August 15, 2021 Share Posted August 15, 2021 I don't want to hijack the thread, but that conversion is fantastic. I did not replace Abaddon's claw hand, I merely added to it. I won't derail the thread, but if your curious mine's here: http://www.bolterandchainsword.com/topic/353152-update-to-prots-thousand-sons-p2-scarab-occult-finished/?p=5730866 The problem I had with idea of replacing the hand is I wanted to add a magic 'ball' to it and it needed a mighty large hand to do so. battle captain corpus, Venerable Jazzman and Tichinde 3 Back to top Link to comment https://bolterandchainsword.com/topic/371289-converting-abbaddon/#findComment-5730869 Share on other sites More sharing options...
Tichinde Posted August 15, 2021 Share Posted August 15, 2021 (edited) Thanks Prot! Praise from the high magister is always welcome I thought long and hard about what to use as ol' Abby is slightly larger than the average terminator (as noted above) and then I remembered about the Primarchs. There is probably something else in the range that might work but I opted for Magnus.... Edited August 15, 2021 by Tichinde Prot 1 Back to top Link to comment https://bolterandchainsword.com/topic/371289-converting-abbaddon/#findComment-5730881 Share on other sites More sharing options...
Montuhotep Posted August 16, 2021 Author Share Posted August 16, 2021 Both are things of beauty, gentlemen. Tichinde 1 Back to top Link to comment https://bolterandchainsword.com/topic/371289-converting-abbaddon/#findComment-5731277 Share on other sites More sharing options...
VanDutch Posted August 22, 2021 Share Posted August 22, 2021 If it’s of any use, a friend of mine recently converted Abaddon to an Iron Warriors Chaos Lord; https://www.instagram.com/p/CMqTLgonEw-/?utm_medium=copy_link Link to comment https://bolterandchainsword.com/topic/371289-converting-abbaddon/#findComment-5733478 Share on other sites More sharing options...
