Joe Posted August 17, 2021 Share Posted August 17, 2021 Something I'm certain has already been looked at for the forum software update in the future, but I'd love to double down on it as well - notifications for when your post has been quoted, or you have been mentioned specifically, would be fantastic. walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/371319-quote-mention-notifications/ Share on other sites More sharing options...
Grotsmasha Posted August 17, 2021 Share Posted August 17, 2021 You *should* already be receiving Notifications when you are quoted, if you are not have a look at your settings there should be a toggle. As for mentions / tagging, IIRC, this a feature of the software we will be upgrading to. WarriorFish, battle captain corpus and Joe 3 Back to top Link to comment https://bolterandchainsword.com/topic/371319-quote-mention-notifications/#findComment-5731653 Share on other sites More sharing options...
Brother Tyler Posted August 17, 2021 Share Posted August 17, 2021 The notifications options includes an option for receiving notifications, either via email (which has been disabled, so that option won't work until we fix the issues forcing us to disable the email system) and/or by notification, when someone quotes your post. I have never tested it, but I assume that it only works when someone uses the Quote or MultiQuote button to quote a member (I get a ton of notifications already so I've minimized the triggers for notifications). There are two other ways that I know of to quote people that probably won't work. One is to copy and paste, something I have to do when I want to quote a post from one discussion in another discussion. The other is to just use the BBCode, manually entering the quote.The notification system doesn't support notifying you when your name is mentioned in a post. In practice, that wouldn't work quite as well considering the number of members whose names double as common phrases or characters or whose names are often abbreviated or turned into acronyms. Your name, Joe, for example, wouldn't work quite as well because you would then receive a notification every time someone entered the word "Joe" in their post, whether they were referring to you or not. The Emperor's Champion, meanwhile, could refer to the member or the character. Grotsmasha, on the other hand, has a fairly unique name that would likely only be used in reference to him. "Brother Tyler" isn't likely to be used except in reference to me (though I can think of a few cases where it might be used otherwise). However, people occasionally shorten my name to either "Tyler" or "BT" in posts. There are multiple other members whose display names include "Tyler" and "BT" is more often used to refer to the Black Templars. So notifications for mentions of names doesn't seem likely.If anyone is curious enough to see when they are mentioned in posts, most can simply use the search engine. That, too, has its issues as it only works with search strings that are four or more characters in length (so you're out of luck again, Joe - you should have stuck with one of your previous display names ). Joe 1 Back to top Link to comment https://bolterandchainsword.com/topic/371319-quote-mention-notifications/#findComment-5731665 Share on other sites More sharing options...
WarriorFish Posted August 17, 2021 Share Posted August 17, 2021 Yes, notifications can be turned on for when you are quoted to appear in the notifications bar at the top as normal. Email notifications are disabled currently as with all other emails, as Grot notes more direct mentions will be an available option in the upgraded software Joe and walter h 2 Back to top Link to comment https://bolterandchainsword.com/topic/371319-quote-mention-notifications/#findComment-5731667 Share on other sites More sharing options...
Daimyo-Phaeron Lenoch Posted August 21, 2021 Share Posted August 21, 2021 (edited) …that’s a thing? Edited August 21, 2021 by Daimyo-Phaeron Lenoch Link to comment https://bolterandchainsword.com/topic/371319-quote-mention-notifications/#findComment-5733102 Share on other sites More sharing options...
Brother Tyler Posted August 21, 2021 Share Posted August 21, 2021 …that’s a thing? Huh. I…may have to turn that on (for notifications at least). Not that I’m a very quotable person , so I doubt it’ll actually come up much. You never know when someone might quote you. walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/371319-quote-mention-notifications/#findComment-5733296 Share on other sites More sharing options...
Daimyo-Phaeron Lenoch Posted August 22, 2021 Share Posted August 22, 2021 …that’s a thing? Huh. I…may have to turn that on (for notifications at least). Not that I’m a very quotable person , so I doubt it’ll actually come up much. You never know when someone might quote you. This presupposes I remembered to actually do the thing. ;) Link to comment https://bolterandchainsword.com/topic/371319-quote-mention-notifications/#findComment-5733535 Share on other sites More sharing options...
