Gloomfoe Posted August 17, 2021 Share Posted August 17, 2021 (edited) I kit-bashed some flash gitz and Nobz together to make some Freeboota Flash Nobz! I've been wanting to do this for a while, I've always been saddened by the cool torsos of the flash gitz being covered up by their humongous guns. No more! This was a pretty easy process. You have to clip the necks a bit to get them to go on straight, otherwise they are all looking to their left. Edited August 17, 2021 by Gloomfoe Closet Skeleton, Brother Dallo, Magos Takatus and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/371331-flash-nobz/ Share on other sites More sharing options...
Brother Dallo Posted August 18, 2021 Share Posted August 18, 2021 Those are some pretty cool looking ladz. Out of curiosity, what is the size difference for the bodies from the two kits? Dallo Link to comment https://bolterandchainsword.com/topic/371331-flash-nobz/#findComment-5732265 Share on other sites More sharing options...
Gloomfoe Posted August 18, 2021 Author Share Posted August 18, 2021 Same size. The bodies are split by front halves and back halves on both kits, and the flash git fronts fit perfectly to the back halves of the nobz. You have to experiment a bit as some fit better than others. I haven't tried making flash gitz with the nob fronts, but I expect it to work the same Link to comment https://bolterandchainsword.com/topic/371331-flash-nobz/#findComment-5732300 Share on other sites More sharing options...
Gloomfoe Posted August 20, 2021 Author Share Posted August 20, 2021 Cleaned them up and highlighted them. Malakithe 1 Back to top Link to comment https://bolterandchainsword.com/topic/371331-flash-nobz/#findComment-5732822 Share on other sites More sharing options...
