angrom Posted August 19, 2021 Share Posted August 19, 2021 (edited) Hi All, I am wondering if a chaplain attempt to recite a litany in his command phase and fail the roll. Does he still count has having recited a litany that turn? If not empyric declamation could be used as a fail safe to pass the litany after failing reciting it in command phase no? Edited August 19, 2021 by angrom Link to comment https://bolterandchainsword.com/topic/371352-gk-chaplain-and-empyric-declamation/ Share on other sites More sharing options...
Holier Than Thou Posted August 19, 2021 Share Posted August 19, 2021 There is nothing I can see that would stop you using the stratagem after a failed attempt. There is a specific rule regarding attempting to cast a Psychic Power more than once, there is no such rule regarding attempting to recite a litany. Link to comment https://bolterandchainsword.com/topic/371352-gk-chaplain-and-empyric-declamation/#findComment-5732510 Share on other sites More sharing options...
RedemptionNL Posted August 19, 2021 Share Posted August 19, 2021 No. You do not roll to see if you recite it or not. You recite the litany, and then roll to see if it was inspiring or not. So even if you failed to inspire, you still recited the litany and no chaplain can recite it again until your next Command phase. librisrouge, Ticaliation, Cryminysakes and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/371352-gk-chaplain-and-empyric-declamation/#findComment-5732513 Share on other sites More sharing options...
Holier Than Thou Posted August 19, 2021 Share Posted August 19, 2021 Rereading the Chaplain section, I have to change my original position and agree with RedemptionNL. RedemptionNL and Cryminysakes 2 Back to top Link to comment https://bolterandchainsword.com/topic/371352-gk-chaplain-and-empyric-declamation/#findComment-5732526 Share on other sites More sharing options...
