Trokair Posted August 19, 2021 Share Posted August 19, 2021 I know the model does not come with a base, and in any case I am using a Carnodon as the basis for my Predator for my Thousand Sons. But for both transport, and to fit in better with the army I was thinking of putting it on a base. What size would people suggest/have used? Also any pictures would be great to judge to effect. battle captain corpus 1 Back to top Link to comment https://bolterandchainsword.com/topic/371363-predatorrhino-base-sieze/ Share on other sites More sharing options...
Jings Posted August 20, 2021 Share Posted August 20, 2021 (edited) I've done it. Knight-sized base fits perfectly. I used two layers of cork to make a road, with indents on the top layer to let the Rhino tracks sit comfortably. I shaved off a bit of the tracks, and using the indents attached a couple decent sized magnets so I can remove it from the base. Don't have a picture right now of the base with the Rhino removed, but these should give you an idea. https://i.imgur.com/MJG6Zpr.jpeg https://i.imgur.com/kpn1Uzc.jpeg Edited August 20, 2021 by Jings Commisar Necros, Trokair and Venerable Jazzman 3 Back to top Link to comment https://bolterandchainsword.com/topic/371363-predatorrhino-base-sieze/#findComment-5732812 Share on other sites More sharing options...
Trokair Posted August 21, 2021 Author Share Posted August 21, 2021 Thanks, Knight bases are big. Do you think the slightly smaller 120x92mm oval (flyer) base would work? Link to comment https://bolterandchainsword.com/topic/371363-predatorrhino-base-sieze/#findComment-5733247 Share on other sites More sharing options...
Halandaar Posted August 30, 2021 Share Posted August 30, 2021 Like Jings I went for the Knight-sized oval for my Sororitas vehicles and found it pretty much perfect; the flyer size oval felt too small, with bits of the tank hanging over the edges. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/371363-predatorrhino-base-sieze/#findComment-5736719 Share on other sites More sharing options...
MegaVolt87 Posted August 31, 2021 Share Posted August 31, 2021 Use a large rectangular base, non- hover tanks without flight stands look odd on round/ oval bases. Link to comment https://bolterandchainsword.com/topic/371363-predatorrhino-base-sieze/#findComment-5736756 Share on other sites More sharing options...
TrawlingCleaner Posted August 31, 2021 Share Posted August 31, 2021 I use the 120x92mm for my vehicles, although they are smaller than modern sculpts. The modern Rhino should fit on the base with a small amount of overhang Trokair, Venerable Jazzman and battle captain corpus 3 Back to top Link to comment https://bolterandchainsword.com/topic/371363-predatorrhino-base-sieze/#findComment-5736810 Share on other sites More sharing options...
Halandaar Posted August 31, 2021 Share Posted August 31, 2021 For direct comparison, here's my Castigator on the Knight-sized 170x105 oval And the same model on an upturned flyer-sized (120x92) oval (I didn't have one without a flight-stand stuck to it) Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/371363-predatorrhino-base-sieze/#findComment-5736832 Share on other sites More sharing options...
Trokair Posted August 31, 2021 Author Share Posted August 31, 2021 Thank you all for your answers and pictures, now I just need to actually reach a decision. Link to comment https://bolterandchainsword.com/topic/371363-predatorrhino-base-sieze/#findComment-5736872 Share on other sites More sharing options...
battle captain corpus Posted September 9, 2021 Share Posted September 9, 2021 I agree that the 120x90mm (Dreadknight?) base size is the best I think. BCC Link to comment https://bolterandchainsword.com/topic/371363-predatorrhino-base-sieze/#findComment-5740239 Share on other sites More sharing options...
INKS Posted September 11, 2021 Share Posted September 11, 2021 Sorry I don't have much to add. I just wanted to say that I like seeing Rhinos and such on bases. I don't see it enough. I like it. Doghouse 1 Back to top Link to comment https://bolterandchainsword.com/topic/371363-predatorrhino-base-sieze/#findComment-5740556 Share on other sites More sharing options...
Trokair Posted September 11, 2021 Author Share Posted September 11, 2021 So I ended up going with the larger 170mm oval. This is how it looks: AenarIT 1 Back to top Link to comment https://bolterandchainsword.com/topic/371363-predatorrhino-base-sieze/#findComment-5740605 Share on other sites More sharing options...
