The Neverborn Posted August 24, 2021 Share Posted August 24, 2021 As the topic says I've washed one of my models with a mixture of Durchi Violet, Seraphim Sepia and Water, roughly 1:1:4 the model has a "wet look" even after it's dried. How would I have prevented this? BBA Link to comment https://bolterandchainsword.com/topic/371413-shade-washes-leave-a-wet-look/ Share on other sites More sharing options...
Imren Posted August 24, 2021 Share Posted August 24, 2021 Mix in a bit of matte medium, then it will dry with a more flat texture. https://acrylicosvallejo.com/en/product/fine-arts/auxiliaries-fine-arts/matt-fluid-medium-26545/ The Neverborn and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/371413-shade-washes-leave-a-wet-look/#findComment-5734411 Share on other sites More sharing options...
Grotsmasha Posted August 24, 2021 Share Posted August 24, 2021 You can also hit the model now with Lahmian Medium to knock back the shine. Firedrake Cordova and The Neverborn 2 Back to top Link to comment https://bolterandchainsword.com/topic/371413-shade-washes-leave-a-wet-look/#findComment-5734419 Share on other sites More sharing options...
Firedrake Cordova Posted August 24, 2021 Share Posted August 24, 2021 As Imren and Grotsmasha have said, you can either add some matt medium to your mix, or paint over it with matt medium once it's dry. I know that some people (Darren Latham) paint over their models with Lahmian Medium (matt medium) in order to unify the finish across all the areas. The Neverborn 1 Back to top Link to comment https://bolterandchainsword.com/topic/371413-shade-washes-leave-a-wet-look/#findComment-5734422 Share on other sites More sharing options...
Xenith Posted August 24, 2021 Share Posted August 24, 2021 Don't thin the washes with water, it can cause a funny reaction that changes the finish, use lahmian medium instead. Those washes only dry glossy/wet for me when I apply too much and they pool in recesses - could this have happened? The Neverborn, Kaldoth, Bryan Blaire and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/371413-shade-washes-leave-a-wet-look/#findComment-5734441 Share on other sites More sharing options...
Scammel Posted August 24, 2021 Share Posted August 24, 2021 Sometimes I get a particularly glossy effect when I'm a schmuck and don't shake the pot enough prior. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/371413-shade-washes-leave-a-wet-look/#findComment-5734555 Share on other sites More sharing options...
Firedrake Cordova Posted August 24, 2021 Share Posted August 24, 2021 Sometimes I get a particularly glossy effect when I'm a schmuck and don't shake the pot enough prior. That's a good point - when using Contrast and Shade paints, turn the pot upside down (having made sure it is properly closed first! ;)), and if you see anything clinging to the bottom, give it another shake. Personally, I've put AK Interactive "Steel Shakers" (ball bearings) in all of them (and every other paint pot...). Link to comment https://bolterandchainsword.com/topic/371413-shade-washes-leave-a-wet-look/#findComment-5734576 Share on other sites More sharing options...
Aramis K Posted August 31, 2021 Share Posted August 31, 2021 I find lots of paints have variable level of gloss and painting over with clear medium can transform the look of a piece. Really helps smooth the transitions between colours as intended. Link to comment https://bolterandchainsword.com/topic/371413-shade-washes-leave-a-wet-look/#findComment-5736991 Share on other sites More sharing options...
MegaVolt87 Posted September 1, 2021 Share Posted September 1, 2021 Even with shaking, GW washes and contrast paints behave differently depending how much is left in the pot. For example a half full pot of Nuln Oil vs a quarter empty/ full one etc. Even with the same recipe it will never quite match upon closer inspection using pots at various stages of full. I think a gloss or matte varnish is the answer to eliminate this variance IMO. Link to comment https://bolterandchainsword.com/topic/371413-shade-washes-leave-a-wet-look/#findComment-5737105 Share on other sites More sharing options...
