Ichar Posted August 27, 2021 Share Posted August 27, 2021 My regular opponent and I were having a disagreement regarding the Infernal Master pacts. How many pacts can he perform in a turn? I read it that he knows 2 and can use one. If he takes the relic, he knows three pacts but can still only cast one. My opponents says that he knows 2, can cast 2, and can know and cast a third with the relic. What do you think? I really think the wording could have been clearer on the data sheet. Link to comment https://bolterandchainsword.com/topic/371476-infernal-master-how-many-pacts-per-turn/ Share on other sites More sharing options...
Trokair Posted August 27, 2021 Share Posted August 27, 2021 To me the rule reads clear, he knows two (or three with the relic) and he can make one each command phase, otherwise it would say he can make ‘each pact he knows’, not ‘a pact he knows’. Iron Sage, Prot, The Yncarne and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/371476-infernal-master-how-many-pacts-per-turn/#findComment-5735897 Share on other sites More sharing options...
Ichar Posted August 29, 2021 Author Share Posted August 29, 2021 To me the rule reads clear, he knows two (or three with the relic) and he can make one each command phase, otherwise it would say he can make ‘each pact he knows’, not ‘a pact he knows’. Agreed. Thanks for the answer. I just wish they would be a bit more concise on things like this. Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/371476-infernal-master-how-many-pacts-per-turn/#findComment-5736189 Share on other sites More sharing options...
Theredknight Posted August 29, 2021 Share Posted August 29, 2021 Yes a bit like a chaplain, just more wizard based Link to comment https://bolterandchainsword.com/topic/371476-infernal-master-how-many-pacts-per-turn/#findComment-5736228 Share on other sites More sharing options...
Xenith Posted August 30, 2021 Share Posted August 30, 2021 Thing it, the book doesn't say how many times the Master can attempt to perform "a pact he knows", so I fully understand the confusion. The only restriction on making pacts is that it has to be one that has not been attempted so far this turn. Compare that with a Chaplain which says : "the model can recite one litany..." It can really be read both ways, but I agree rules as intended is one pact per turn - which actually makes the armour pointless. Link to comment https://bolterandchainsword.com/topic/371476-infernal-master-how-many-pacts-per-turn/#findComment-5736481 Share on other sites More sharing options...
