Glute Posted August 30, 2021 Share Posted August 30, 2021 If a unit casts 'xx' psychic power on a enemy unit and it is denied can another unit cast the same power on the same enemy unit? For Santic powers I believe the answer is YES based on 'Psychic Confluence' rule. For Brotherhood power if your in Tide of Escalation I believe the answer is YES also. Thanks Link to comment https://bolterandchainsword.com/topic/371497-recast-denied-psychic-power-from-another-unit/ Share on other sites More sharing options...
Grimlock Posted August 30, 2021 Share Posted August 30, 2021 (edited) The answer is yes, a deny only denies the power you are casting, with that unit. So you cast smite with unit 1 and it is denied, unit 2 can attempt to cast smite again. Edited August 31, 2021 by Grimlock XeonDragon 1 Back to top Link to comment https://bolterandchainsword.com/topic/371497-recast-denied-psychic-power-from-another-unit/#findComment-5736390 Share on other sites More sharing options...
Lukoi Posted August 30, 2021 Share Posted August 30, 2021 Out of curiousity, are GK immune to this rule: MANIFESTING PSYCHIC POWERS The same PSYKER unit cannot attempt to manifest Smite more than once during the same battle round. When you select a PSYKER unit to manifest psychic powers, you select one psychic power that unit knows and attempt to manifest it. With the exception of Smite, you cannot attempt to manifest the same psychic power more than once in the same battle round, even with different PSYKER units. XeonDragon 1 Back to top Link to comment https://bolterandchainsword.com/topic/371497-recast-denied-psychic-power-from-another-unit/#findComment-5736403 Share on other sites More sharing options...
Skywrath Posted August 30, 2021 Share Posted August 30, 2021 (edited) Out of curiousity, are GK immune to this rule: MANIFESTING PSYCHIC POWERS The same PSYKER unit cannot attempt to manifest Smite more than once during the same battle round. When you select a PSYKER unit to manifest psychic powers, you select one psychic power that unit knows and attempt to manifest it. With the exception of Smite, you cannot attempt to manifest the same psychic power more than once in the same battle round, even with different PSYKER units. No, that limit still applies to Dominus powers, with perhaps the exception being the tide of convergence. Edited August 30, 2021 by Skywrath Lukoi and XeonDragon 2 Back to top Link to comment https://bolterandchainsword.com/topic/371497-recast-denied-psychic-power-from-another-unit/#findComment-5736406 Share on other sites More sharing options...
Lukoi Posted August 30, 2021 Share Posted August 30, 2021 Cool thanks. Skywrath 1 Back to top Link to comment https://bolterandchainsword.com/topic/371497-recast-denied-psychic-power-from-another-unit/#findComment-5736409 Share on other sites More sharing options...
