Lord_Ikka Posted October 29, 2021 Share Posted October 29, 2021 I'm looking at using an Ogroid Myrmidon as a Word Bearers DP- cutting off the head of the spear and making it into a large debased crozius. Then the shield arm will have the shield removed and a heavy bolter put in its place as a warp bolter with some GS detailing. Strips of GS "nailed" to the back to represent wings and be Word Bearer-ie... Seems like it will be big enough to be a decent stand-in. Tallarn Commander 1 Back to top Link to comment https://bolterandchainsword.com/topic/371640-alternative-daemon-prince/page/3/#findComment-5758513 Share on other sites More sharing options...
Quixus Posted October 29, 2021 Share Posted October 29, 2021 Is the warp bolter still a legal option in 9th? Link to comment https://bolterandchainsword.com/topic/371640-alternative-daemon-prince/page/3/#findComment-5758611 Share on other sites More sharing options...
Dr_Ruminahui Posted October 29, 2021 Share Posted October 29, 2021 (edited) Until we get a new codex that doesn't include it, yes. We are still operating under the same codex as we did in 8e, so nothing has changed in terms of wargear options. I'm concerned that a heavy bolter would be ridiculously huge, Lord Ikka - you might want to look at cutting it down or converting some other gun (perhaps one of the primaris rifles) instead. The cursed crosius is a good idea - any idea what you would use for the head? As well, I assume you would use the crosius to represent the sword option? Edited October 29, 2021 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/371640-alternative-daemon-prince/page/3/#findComment-5758876 Share on other sites More sharing options...
Lord_Ikka Posted October 30, 2021 Share Posted October 30, 2021 Until we get a new codex that doesn't include it, yes. We are still operating under the same codex as we did in 8e, so nothing has changed in terms of wargear options. I'm concerned that a heavy bolter would be ridiculously huge, Lord Ikka - you might want to look at cutting it down or converting some other gun (perhaps one of the primaris rifles) instead. The cursed crosius is a good idea - any idea what you would use for the head? As well, I assume you would use the crosius to represent the sword option? I'll have to see when I get him- the heavy bolter in question is the FW Mars pattern from the HH line, so I think it is a little bit smaller, or at least thinner, than 40k heavy bolters. Cutting it down shouldn't be a problem at all. Depends- I'm doing a small (8-man) Word Bearer "kill-team" as more of a diorama/painting break than an actual army at the moment, but I would probably use it as the axe given that it will be big and unwieldy. Right now I'm looking at scratch-builging the crozius- can't find a good mace head big enough that will look suitably nasty, so I've got a couple of ideas. The main one is using an old plastic chrismas tree lightbulb that is somewhat geodesic in design and adding some spikes and flourishes to it. We'll have to see when I get my hands on the actual model. Link to comment https://bolterandchainsword.com/topic/371640-alternative-daemon-prince/page/3/#findComment-5758925 Share on other sites More sharing options...
TPS Posted October 30, 2021 Share Posted October 30, 2021 I used the Morghast kit from AoS, a Flesh Hound head and some extra chains and bits to make my Khornate DP. The bones and screaming souls on the model should work on differently flavoured Princes as well. Vesalius, Daemon Prince Marbas, TwinOcted and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/371640-alternative-daemon-prince/page/3/#findComment-5759203 Share on other sites More sharing options...
Dr_Ruminahui Posted November 1, 2021 Share Posted November 1, 2021 (edited) That's a cool demon prince, TPS - very creative and no confusion over which god he/it draws his/its power from. Is the halo/collar (the gold bit above the head) part of the hound, or is it from a different source? Edited November 1, 2021 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/371640-alternative-daemon-prince/page/3/#findComment-5759961 Share on other sites More sharing options...
Closet Skeleton Posted November 1, 2021 Share Posted November 1, 2021 That's a cool demon prince, TPS - very creative and no confusion over which god he/it draws his/its power from. Is the halo/collar (the gold bit above the head) part of the hound, or is it from a different source? Looks like its from a Blood crusher. Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/371640-alternative-daemon-prince/page/3/#findComment-5760078 Share on other sites More sharing options...
