I wasn't going to add wings - he's floaty enough I think - but I've never seen either Nagash nor Magnus in the flesh, so I don't know the size difference between the two.
My group isn't overly concerned with the minutiae, but I believe Magnus is quite a big guy. Should I put wings on him for the sake of fairness?
Just seen that Nagash is actually on a bigger base than Magnus so maybe he would be big enough.
Edited by Valkyrion
As Mordas says, Magnus has wings. While Nagash is taller (25cm/9.8in compared to Magnus' being slightly shorter than an Imperial Knight), Magnus' wings are about 4-6 inches in width.
Just using Nagash without adding anything to widen him is major modelling for advantage, even if you're not intending of such.
I think I'll stick with magnus.
To try and stick with the ghostly theme, I was thinking of doing either;
1) ghostly armour parts and organic parts painted normally
or
2) ghostly organic parts and armour parts painted normally
What do you think?
Ghostly organic parts and painted armour like a sentient magnus sized suit of armour flying around could be cool, but ghostly armour would tie in with the theme of the army.
Register a new account
Sign in
