greatcrusade08 Posted September 14, 2021 Share Posted September 14, 2021 (edited) hey guys if i build a grot mega tank with 3 kustom mega blastas and 2x2 kustom mega blastas. If i give the tank the mek cutom job "extra kustom weapon" how many extra shots do i actually get, my friends and i cant work it out. rule states: Each time this model shoots with a kustom mega blasta make one additional attack with that weapon the weapons are D3 shots and there are 7 weapons is it 7D3+1 is it done before numbers of shots is worked out so 7+1D3 is it one extra per weapon so 7D3+7 or 7+7D3 thanks guys Edited September 14, 2021 by greatcrusade08 Link to comment https://bolterandchainsword.com/topic/371693-orks-extra-custom-weapon/ Share on other sites More sharing options...
Bryan Blaire Posted September 14, 2021 Share Posted September 14, 2021 Each time the model shoots with a kustom mega blasta, make one additional attack with that weapon - so if you have seven kustom mega blastas on one vehicle, the attack sequence would go like this: Attack w/ Weapon 1: D3+1 Attack w/ Weapon 2: D3+1 Attack w/ Weapon 3: D3+1 Attack w/ Weapon 4: D3+1 Attack w/ Weapon 5: D3+1 Attack w/ Weapon 6: D3+1 Attack w/ Weapon 7: D3+1 If you are fast rolling all the attacks together, this would work out to 7D3+7. The question I have is whether the “kustom job” actually gives that benefit to every weapon on the tank, or does it specify that you choose a weapon? If you choose a single blasta, then only one weapon is D3+1, not all. Also, you have to work out your actual weapons - you stated 2x2 kustom mega blastas - that seems like you only have 2 weapons there, not four. In that case, it would be: Attack w/Kustom Mega Blasta 1: D3+1 Attack w/Kustom Mega Blasta 2: D3+1 Attack w/Kustom Mega Blasta 3: D3+1 Attack w/ 2xKustom Mega Blasta 1: D3+D3+1 Attack w/ 2xKustom Mega Blasta 2: D3+D3+1 Link to comment https://bolterandchainsword.com/topic/371693-orks-extra-custom-weapon/#findComment-5741485 Share on other sites More sharing options...
greatcrusade08 Posted September 14, 2021 Author Share Posted September 14, 2021 (edited) The question I have is whether the “kustom job” actually gives that benefit to every weapon on the tank, or does it specify that you choose a weapon? If you choose a single blasta, then only one weapon is D3+1, not all. Thanks Bryan im thinking considering its a ten point upgrade they prob expect it will only be used once, but the wording is exactly as i have written it, which suggests its used everytime you fire with a kmb weapon Edited September 14, 2021 by greatcrusade08 Link to comment https://bolterandchainsword.com/topic/371693-orks-extra-custom-weapon/#findComment-5741487 Share on other sites More sharing options...
Slasher956 Posted September 16, 2021 Share Posted September 16, 2021 As written.... its poorly written...However I belive the most consistant reading is the 2nd of Bryans posiblities... that is each weapon adds +1, so its 3 x D3+1 & 2 x 2D3+1... or if all weapons are firing at one target 7D3+5 Link to comment https://bolterandchainsword.com/topic/371693-orks-extra-custom-weapon/#findComment-5742016 Share on other sites More sharing options...
Brother Sergeant Tiberius Posted September 16, 2021 Share Posted September 16, 2021 This has been faq'ed the kustom mega blasta kystom job is only available on mek,big mek or spanner model according to the newest faq. Dr_Ruminahui and Slasher956 2 Back to top Link to comment https://bolterandchainsword.com/topic/371693-orks-extra-custom-weapon/#findComment-5742070 Share on other sites More sharing options...
