Cris R Posted September 18, 2021 Share Posted September 18, 2021 I’m in the process of putting together a paint scheme for my Blackshields and wanted some tips on an idea I’m kicking around. The idea is doing Zenithal priming using silvers and then using a grey ink, glaze, or something like Contrast paints so it looks more matte without completely losing some of the metallic sheen. Has anyone else done this who can give me pointers? Thanks! Link to comment https://bolterandchainsword.com/topic/371734-glaze-or-inks-over-metallic-zenithal-primed-models/ Share on other sites More sharing options...
Grotsmasha Posted September 19, 2021 Share Posted September 19, 2021 Haven't tried greys specifically, but contrast works well over metallics. I'd recommend doing 50/50 medium / contrast just in case it's too powerful straight from the pot. Much easier to add more than take it off Cris R 1 Back to top Link to comment https://bolterandchainsword.com/topic/371734-glaze-or-inks-over-metallic-zenithal-primed-models/#findComment-5743062 Share on other sites More sharing options...
tychobi Posted September 19, 2021 Share Posted September 19, 2021 I use this a lot. Love my golden transparent paints. I encourage you to push contrast and not wash too liberally. Or go back and highlight Cris R 1 Back to top Link to comment https://bolterandchainsword.com/topic/371734-glaze-or-inks-over-metallic-zenithal-primed-models/#findComment-5743521 Share on other sites More sharing options...
Cris R Posted September 19, 2021 Author Share Posted September 19, 2021 The 50/50 Contrast/Contrast Medium mix is what I have in mind but I'm also mulling over using the Scale 75 Instant Color black since that range is much thinner than the Contrast line. Has anyone used those for this purpose? Link to comment https://bolterandchainsword.com/topic/371734-glaze-or-inks-over-metallic-zenithal-primed-models/#findComment-5743539 Share on other sites More sharing options...
jaxom Posted September 20, 2021 Share Posted September 20, 2021 (edited) EDIT: took out not entirely relevant, shinier, full recipe; replaced it with another example. Here's a WIP shot of Leadbelcher and the contrast paint, only. And Duncan Rhodes doing Basilicanum Grey over Leadbelcher Edited September 20, 2021 by jaxom Link to comment https://bolterandchainsword.com/topic/371734-glaze-or-inks-over-metallic-zenithal-primed-models/#findComment-5743566 Share on other sites More sharing options...
Kastor Krieg Posted September 20, 2021 Share Posted September 20, 2021 Vallejo Metal Color "Exhaust Manifold" airbrushed over black primer, washed with Black Templar Contrast. Basically Leadbelcher and BT Contrast. infyrana and Cris R 2 Back to top Link to comment https://bolterandchainsword.com/topic/371734-glaze-or-inks-over-metallic-zenithal-primed-models/#findComment-5743571 Share on other sites More sharing options...
Cris R Posted September 20, 2021 Author Share Posted September 20, 2021 Vallejo Metal Color "Exhaust Manifold" airbrushed over black primer, washed with Black Templar Contrast. Basically Leadbelcher and BT Contrast. That looks really smooth. How did you avoid the splotchy look you regularly get with Contrast paints? Link to comment https://bolterandchainsword.com/topic/371734-glaze-or-inks-over-metallic-zenithal-primed-models/#findComment-5743581 Share on other sites More sharing options...
Kastor Krieg Posted September 20, 2021 Share Posted September 20, 2021 That looks really smooth. How did you avoid the splotchy look you regularly get with Contrast paints? Metallics are a bit "glossy" surfaces themselves. The rest is pooling control and using a larger brush, but not overloading it with paint. Cris R 1 Back to top Link to comment https://bolterandchainsword.com/topic/371734-glaze-or-inks-over-metallic-zenithal-primed-models/#findComment-5743628 Share on other sites More sharing options...
Cris R Posted September 21, 2021 Author Share Posted September 21, 2021 That looks really smooth. How did you avoid the splotchy look you regularly get with Contrast paints? Metallics are a bit "glossy" surfaces themselves. The rest is pooling control and using a larger brush, but not overloading it with paint. I use gloss coats and oil washes, so I know the benefits of having smooth surfaces when using these kinds of techniques. Any thoughts on applying Contrast over gloss coats on metal primers? Link to comment https://bolterandchainsword.com/topic/371734-glaze-or-inks-over-metallic-zenithal-primed-models/#findComment-5744198 Share on other sites More sharing options...
Rik Lightstar Posted September 21, 2021 Share Posted September 21, 2021 (edited) Replied to wrong topic, le face-palm Rik Edited September 21, 2021 by Rik Lightstar Link to comment https://bolterandchainsword.com/topic/371734-glaze-or-inks-over-metallic-zenithal-primed-models/#findComment-5744643 Share on other sites More sharing options...
