Macragge-T Posted September 24, 2021 Share Posted September 24, 2021 (edited) Does anyone know where I can find replacement bits for the primaris agressors? I managed to glue two torsos together without installing the heads first. Major noob mistake, I know. I'd rather not buy a whole second box for the pieces, rather not scratch the heads up trying to get them in either. Edited September 27, 2021 by Brother Tyler No sales/trades are allowed in the discussion forums. Link to comment https://bolterandchainsword.com/topic/371795-looking-for-replacement-pieces-for-primaris-agressors/ Share on other sites More sharing options...
Dantay VI Posted September 24, 2021 Share Posted September 24, 2021 Have you tried some bits sites or ebay? https://www.ebay.co.uk/itm/313232462001?hash=item48ee1c10b1:g:bG4AAOSwDcpZuYeT Link to comment https://bolterandchainsword.com/topic/371795-looking-for-replacement-pieces-for-primaris-agressors/#findComment-5745371 Share on other sites More sharing options...
Grotsmasha Posted September 24, 2021 Share Posted September 24, 2021 Does anyone know where I can find replacement bits for the primaris agressors? I managed to glue two torsos together without installing the heads first. Major noob mistake, I know. I'd rather not buy a whole second box for the pieces, rather not scratch the heads up trying to get them in either. Or perhaps someone has a few of them just laying around? Name your price. My recommendation is to snip (preferably saw off with a hobby saw) the ball / necks from underneath, then glue those into place, then without the necks the helms should fit through the gap, and because you've already placed the necks, they will have a secure place to glue to. I don't recall if Aggressors have the pin that locks the neck to a certain position, but these are completely unnecessary and can be discarded entirely. Cheers, Jono Halandaar and Dantay VI 2 Back to top Link to comment https://bolterandchainsword.com/topic/371795-looking-for-replacement-pieces-for-primaris-agressors/#findComment-5745379 Share on other sites More sharing options...
Cleon Posted September 24, 2021 Share Posted September 24, 2021 Just to add to the above, if it's the full kit (or you have a full kit of Eradicators or heavy intercessors) there should be plenty of spare heads, so no harm in giving that suggestion a try, it won't cost anything if you get the cut wrong. Link to comment https://bolterandchainsword.com/topic/371795-looking-for-replacement-pieces-for-primaris-agressors/#findComment-5745413 Share on other sites More sharing options...
Heraclite Posted September 24, 2021 Share Posted September 24, 2021 When I built my last 3 aggressors, I wanted to keep the head separate for ease of painting, but even with the neck tab removed, it's almost impossible to fit the head through the "hood" opening. I'm glad I dry fitted it in the first place... Maybe you can try shaving a bit of the bottom of the "ball" neck to make it a bit flatter to fit through the opening, you should still have plenty of contact surface on the "sides" of the neck for the glue to stick to. As Cleon said, there's plenty of spare heads in the kit so you can at least have 2/3 tries before having to messily disassemble the body Link to comment https://bolterandchainsword.com/topic/371795-looking-for-replacement-pieces-for-primaris-agressors/#findComment-5745425 Share on other sites More sharing options...
Bryan Blaire Posted September 24, 2021 Share Posted September 24, 2021 Just cut the hoods off completely - then you have nothing blocking your placement of the heads and you have improved the appearance of the models! Don’t forget to post a picture of your works-in-progress in the thread, so we can see, since this is the work in progress forum. Link to comment https://bolterandchainsword.com/topic/371795-looking-for-replacement-pieces-for-primaris-agressors/#findComment-5745452 Share on other sites More sharing options...
Grotsmasha Posted September 24, 2021 Share Posted September 24, 2021 Or the visor look with a shoulderpad.... Osteoclast 1 Back to top Link to comment https://bolterandchainsword.com/topic/371795-looking-for-replacement-pieces-for-primaris-agressors/#findComment-5745549 Share on other sites More sharing options...
