Black Knight Posted October 1, 2021 Share Posted October 1, 2021 (edited) Does anyone know of any designs to properly mount a stubber to the top of the Primaris range of tanks that doesn't involve having the marine's head outside the tank. Looking for something similar to the image below. Either in sold item or model file for me to print. Edited October 1, 2021 by Black_Knight Link to comment https://bolterandchainsword.com/topic/371864-tank-mounted-gun-mounts/ Share on other sites More sharing options...
Firedrake Cordova Posted October 1, 2021 Share Posted October 1, 2021 (edited) No idea about parts currently in the range, but I suppose the question is, how sophisticated do you want it to look? The optics and "other worky bits" on modern remote-operated tank weapons can be quite obvious, but if you look back to WWII the remote-operated machine guns on the Sturmgeschütz and Hetzer basically looked like a regular machine gun. I suppose you could add a "shield" made from plasticard, or remove the trigger grip (to give the impression of being remote-operated)? Edited October 1, 2021 by Firedrake Cordova Link to comment https://bolterandchainsword.com/topic/371864-tank-mounted-gun-mounts/#findComment-5747871 Share on other sites More sharing options...
Halandaar Posted October 1, 2021 Share Posted October 1, 2021 Does anyone know of any designs to properly mount a stubber to the top of the Primaris range of tanks that doesn't involve having the marine's head outside the tank. Looking for something similar to the image below. Either in sold item or model file for me to print. From this Etsy store Firedrake Cordova, Magos Takatus and Black Knight 3 Back to top Link to comment https://bolterandchainsword.com/topic/371864-tank-mounted-gun-mounts/#findComment-5747887 Share on other sites More sharing options...
Sky Potato Posted October 1, 2021 Share Posted October 1, 2021 The Remote Weapons Station (RWS) pictured in the OPs photo - you are aware the majority of the bulk of that station is optics etc? For example, that large, base central glass lens is the TI lens. There’s very little on that station, besides the weapon and ammo feed, that is required to operate the weapon system. Literally a tiny solenoid is all that’s needed. I just model all my vehicle weapons with the no hands option on the grips and just designate everything as future RWS. Which isn’t what you’re asking - but it is plausible. Xenith, Firedrake Cordova and beefeb 3 Back to top Link to comment https://bolterandchainsword.com/topic/371864-tank-mounted-gun-mounts/#findComment-5748072 Share on other sites More sharing options...
Black Knight Posted October 4, 2021 Author Share Posted October 4, 2021 Thanks all but Halandaar hit it right on the head, exactly what I was looking for. Might be able to build that myself with bits but now I a good basis to start with. Link to comment https://bolterandchainsword.com/topic/371864-tank-mounted-gun-mounts/#findComment-5749495 Share on other sites More sharing options...
beefeb Posted October 5, 2021 Share Posted October 5, 2021 The Remote Weapons Station (RWS) pictured in the OPs photo - you are aware the majority of the bulk of that station is optics etc? For example, that large, base central glass lens is the TI lens. There’s very little on that station, besides the weapon and ammo feed, that is required to operate the weapon system. Literally a tiny solenoid is all that’s needed. I just model all my vehicle weapons with the no hands option on the grips and just designate everything as future RWS. Which isn’t what you’re asking - but it is plausible. exactly what i do/have always done.....i see no good reason for a soldier to stick his head out of the tank to operate a pintle mount when RWS does the trick.....its like having a full suit of highly effective battle armour and then taking the helmet off !!!!!!!! Redrandy93 and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/371864-tank-mounted-gun-mounts/#findComment-5749614 Share on other sites More sharing options...
