Skywrath Posted October 4, 2021 Share Posted October 4, 2021 (edited) After painting Draigo, I wonder whether it's possible to create a detachable "compound" base of sorts, akin to the Lion El'Johnson model, where his base is 50mm, and the rest is as a display feature? And the 50mm base is able to be detached. If it is, does anyone know where I can procure those, and for a 40mm base? Link as a reference: https://www.forgeworld.co.uk/en-AU/Lion-ElJonson-2020 Edited October 4, 2021 by Skywrath Link to comment https://bolterandchainsword.com/topic/371888-compound-bases/ Share on other sites More sharing options...
Darkwrath121 Posted October 4, 2021 Share Posted October 4, 2021 (edited) After painting Draigo, I wonder whether it's possible to create a detachable "compound" base of sorts, akin to the Lion El'Johnson model, where his base is 50mm, and the rest is as a display feature? And the 50mm base is able to be detached. If it is, does anyone know where I can procure those, and for a 40mm base? Link as a reference: https://www.forgeworld.co.uk/en-AU/Lion-ElJonson-2020 30k primarchs have 40mm bases, not 50mm, so any of the FW primarch bases (as well as character series models like Raldoron, who has a daemon arm on his) are good to go, if you could find some on a trading group or Eggheadminiatures. Though, some would probably require more work to make other models fit on them. Edited October 4, 2021 by Darkwrath121 Skywrath 1 Back to top Link to comment https://bolterandchainsword.com/topic/371888-compound-bases/#findComment-5748885 Share on other sites More sharing options...
Grotsmasha Posted October 4, 2021 Share Posted October 4, 2021 I've sorted out my resin printer, so if you can find a suitable file, I can probably turn it into a compound base for you :tu: Skywrath 1 Back to top Link to comment https://bolterandchainsword.com/topic/371888-compound-bases/#findComment-5748916 Share on other sites More sharing options...
Tichinde Posted October 4, 2021 Share Posted October 4, 2021 I managed to make one, it wasn't particularly easy. 3D printing might be a better option! http://www.bolterandchainsword.com/topic/331505-tichs-prospero-project-wip-update-26-sep-2021/?p=5517631 or find a suitable one you like from Forgeworld and use that. Dr_Ruminahui and Skywrath 2 Back to top Link to comment https://bolterandchainsword.com/topic/371888-compound-bases/#findComment-5748936 Share on other sites More sharing options...
Skywrath Posted October 4, 2021 Author Share Posted October 4, 2021 (edited) After painting Draigo, I wonder whether it's possible to create a detachable "compound" base of sorts, akin to the Lion El'Johnson model, where his base is 50mm, and the rest is as a display feature? And the 50mm base is able to be detached. If it is, does anyone know where I can procure those, and for a 40mm base? Link as a reference: https://www.forgeworld.co.uk/en-AU/Lion-ElJonson-2020 30k primarchs have 40mm bases, not 50mm, so any of the FW primarch bases (as well as character series models like Raldoron, who has a daemon arm on his) are good to go, if you could find some on a trading group or Eggheadminiatures. Though, some would probably require more work to make other models fit on them. Good to know, thanks! And that website is pretty promising - I had an idea with Draigo standing instead of the Lion with the pile of corpses, just not sure whether he had the same cut-out as this video (fast-forward to 6m onwards to about 8m). I've sorted out my resin printer, so if you can find a suitable file, I can probably turn it into a compound base for you Definitely keen on that my man, I'll start searching! What keywords would my above query be found as? I don't have the exact term to refine my search. I managed to make one, it wasn't particularly easy. 3D printing might be a better option! http://www.bolterandchainsword.com/topic/331505-tichs-prospero-project-wip-update-26-sep-2021/?p=5517631 or find a suitable one you like from Forgeworld and use that. Not quite what I was after.. it's a step in the right direction, but it the display base needs to have a cut-out for a 40mm base, which if I were to put Draigo on it, would look seemless for the base he is on now. Now my bases are fairly basic, meaning it's not hard to make it look seamless but that's the idea. Edited October 4, 2021 by Skywrath Link to comment https://bolterandchainsword.com/topic/371888-compound-bases/#findComment-5749041 Share on other sites More sharing options...
Arkhanist Posted October 4, 2021 Share Posted October 4, 2021 (edited) 3d printing something like this would be relatively straightforward; you'd take the small terrain piece, 'slice' off a suitable chunk for the model and attach a standard 40mm template to the bottom of the small piece; then just subtract a suitably deep 40mm hole so you can put the two together in the real world. Add a couple of magnet mount holes for belt and braces. I could probably slice one up for you if you had one in mind, though shipping an actual base to aus is probably not feasible from UK! The trickier issue is finding a larger display base you like as a starting stl to chop up; they tend to be flat (to put minis on) or vertical. Some commercial "scatter terrain " designs could work though, such as txarli's stuff e.g. statues or titan ruin or rmprintableterrain cast 'n' play do some fantasy ones, e.g. that generator Depends what theme you had in mind, really. Marines are copyrighted, so probably easier to add them manually afterwards if you wanted the 'pile of dead marines' look. Edited October 4, 2021 by Arkhanist Link to comment https://bolterandchainsword.com/topic/371888-compound-bases/#findComment-5749047 Share on other sites More sharing options...
Grotsmasha Posted October 7, 2021 Share Posted October 7, 2021 I've found a bunch of stuff. Base toppers was a good search term. Link to comment https://bolterandchainsword.com/topic/371888-compound-bases/#findComment-5750567 Share on other sites More sharing options...
