angrom Posted October 13, 2021 Share Posted October 13, 2021 Hi All, I was wondering how the secondary SM "Codex warfare" work with ability that change doctrine for a unit Would you say that a unit that count the doctrine as devastator when the rest of army is in tactical would score a VP if it kills a unit with a heavy weapon? If you select this objective, you score victory points as follows: Score 1 victory point at the end of the battle (to a maximum of 5 victory points) for each enemy unit that was destroyed as the result of an attack made with a Heavy or Grenade weapon by an ADEPTUS ASTARTES unit from your army while the Devastator Doctrine was active for your army. Score 1 victory point at the end of the battle (to a maximum of 5 victory points) for each enemy unit that was destroyed as the result of an attack made with a Rapid Fire or Assault weapon by an ADEPTUS ASTARTES unit from your army while the Tactical Doctrine was active for your army. Score 1 victory point at the end of the battle (to a maximum of 5 victory points) for each enemy unit that was destroyed as the result of an attack made with a Pistol or Melee weapon by an ADEPTUS ASTARTES unit from your army while the Assault Doctrine was active for your army. Link to comment https://bolterandchainsword.com/topic/371993-codex-warfare-secondary-and-ability-to-change-doctrines/ Share on other sites More sharing options...
Iron Father Ferrum Posted October 13, 2021 Share Posted October 13, 2021 No. The objectives specifically say while the *army* is in X doctrine, not the *unit.* Link to comment https://bolterandchainsword.com/topic/371993-codex-warfare-secondary-and-ability-to-change-doctrines/#findComment-5753216 Share on other sites More sharing options...
