what are you trying to build exactly? Maybe try something like paper-maché or wood modeling compound? There is stuff in my German hardware store that works quite well, it's called "plastiform". It's essentially ground up wood, which you can mix with water...
Anyone know a decent affordable alternative to milliput for building terrain? I have tried various air drying clays to no avail, they just dont stick to mdf or fiber board even when the board is roughed up. Milliput is frikking expensive for the two little rolls you get.
If i sculpt in miniatures i use a drop of superglue to hold the putty in place.
You could try the same with your cheap putty and some MDF.
I am mostly using milliput for terrain like roads and rivers. I havent actually started the rivers yet since 5 sections of roads just doing the edges and spots in the middle used up 90% of the two little tubes. I still have three more road sections to go.
$15 for two small tubes seems quite expensive, is there another source that sells it cheaper?
I mean... there are also other kinds of 2 part puttys which are intended to be used for household repairs. So there might be a cheaper alternative at the hardware store. The stuff I found so far was only slightly cheaper though...
Maybe the stuff which is used to fill in the gaps in hard wood floor...
I am mostly using milliput for terrain like roads and rivers. ...  is there another source that sells it cheaper?
I've seen people use tile grout, "spackle", and similar for that kind of task. Luke's APS on YouTube might be worth a look? :)
It was one of Luke's videos that I forgot to link in my post above (and have just edited in) - he sells his own variety now, but has in the past used and talked about variations on the same products. Edited by pawl
 Problem is he is still using milliput lol. The dude must have stock in the product or they send him product for promoting it. I would have picked up the book but its $25 shipping to the US for a $39 dollar book. I can watch the Youtube videos though
Edited by Galron
Ah, can't say I noticed that, but I've not been watching closely recently. :blush.:
That sucks. :sad.: There is a PDF version available, if you're interested. :smile.:
  • 2 weeks later...
Magic sculpt is a 2-part epoxy putty that I prefer instead of greenstuff, but also comes in 1lb and 5lb tubs e.g.. In that quantity it's intended for sculpting etc, but would work just as well for terrain and should be substantially cheaper in bulk than milliput in the US, as it's made by an american company, Wesco.
It's also worth pointing out milliput is made in the UK and comes in various grades. The 'standard' yellow/grey is the cheapest, while superfine white is a finer grain and more expensive. Standard milliput is generally the cheapest 'named' epoxy putty in the UK, which is one reason Luke Aps uses it, but I suspect going across the Atlantic adds to the cost - it's only £3 to £4 for 4 oz in the UK.
Edited by Arkhanist
Register a new account
Sign in
