Sir Clausel Posted October 20, 2021 Share Posted October 20, 2021 (edited) Hi everybody and welcome to my crusade! As a long time fan of the Black Templars I knew i had little chance to resist the new release and oh damn are the minis cool as hell! The rules are fine. Could be better but I will manage. Never played competively but still like to get a somewhat decent list. Also I like converting and kitbashing so expect the most of them being a little converted. I dont like the chain your weapon to yourself thing so most of the chains will be removed but the schackles will stay for the most part. Anyway I should start off with some of the models from the new box + some intercessors I kitbashed with the Indomitus assault intercessors and bits form the new box. All the heads will be from the box put i will put some putty in the grills to make them smooth. Thats why most of them are headless atm. And for the Neophytes i really dont like them having no helmet so I put on some firstborn helmets on them and trim the sides juuuuust a bit and I think they fit just fine! and now for the HQs. I got some bits from shapeways to bling up some of them And the Emperors Champion need some adjustment. I didnt like the sword facing that way and after my friend told me the tabard looked like a daiper i couldnt unsee it so i knew i had to do something about it. The picture reaaaaally makes it look rough as hell but as soon as i get some paint on it im sure it will look nicer. Anyway thats all for now. The painting will not start right away as I want to wait for my Duncan Rhodes paints show up. For the paint scheme Im thinking of doing my own little scheme. Black armor with red tabards and shouldpads and gold trim. The crosses will be white. I think I will just my airbrush for some zenithal highlights and try out drybrushing as that seems nowadays to be able to produce some good results fast. I got some time to test out which method I will end up using so might post some of the tests. Edited March 31 by Sir Clausel Brother Kraskor, Tiger9gamer, templargdt and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/ Share on other sites More sharing options...
Brother Kraskor Posted October 20, 2021 Share Posted October 20, 2021 I didn't think I was going to be a fan of Neos with helmets but I really think you've made it work! Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5755808 Share on other sites More sharing options...
9x19 Parabellum Posted October 20, 2021 Share Posted October 20, 2021 Two things. it's spelled "Righteous" also, did you glue the EC's laurel wreath closer down to his helmet? I like it better. Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5755813 Share on other sites More sharing options...
Palmu Posted October 20, 2021 Share Posted October 20, 2021 (edited) Yoo, where did you get the Marshall's helmet from? It looks extremely hype! Â Edit: I'm dum, the source is literally in the text. Checking them out! Edited October 20, 2021 by Palmu Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5755820 Share on other sites More sharing options...
Sir Clausel Posted October 20, 2021 Author Share Posted October 20, 2021 (edited) I didn't think I was going to be a fan of Neos with helmets but I really think you've made it work!I instantly thought of firstborn heads as soon as i saw them. I have never like bare heads apart from a few :p but glad you like them. Two things. Â it's spelled "Righteous" also, did you glue the EC's laurel wreath closer down to his helmet? I like it better. Thank you for the spelling correction! Yes the laurel is now on his head instead of floating over it. It is a liiiittle to big for the head when its not floating so had to trim it i a bit in the back. Yoo, where did you get the Marshall's helmet from? It looks extremely hype! Edit: I'm dum, the source is literally in the text. Checking them out! If you havent found them as there is alooooot then herehttps://www.shapeways.com/product/Q7UTBEMEB/helmet-model-58-freemason?productConfiguration=226435054&etId=200280981&utm_source=automated-contact&utm_medium=email&utm_campaign=order-shipped&utm_content=3 Edited October 20, 2021 by Sir Clausel mytimeprez and Palmu 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5755824 Share on other sites More sharing options...
Gederas Posted October 21, 2021 Share Posted October 21, 2021 Very nice!Can we get some alternate images of the models showing how you sculpted the loincloths on the non-Crusader Squad marines? I need some references for how to do that on my own future Intercessors :yes: Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5755919 Share on other sites More sharing options...
Sir Clausel Posted October 21, 2021 Author Share Posted October 21, 2021 I actually only sculpted the tabard on the Emperors champion and it was really just putting the green stuff in the model and then just trying to put some natural looking folds in it and make it smooth. For smoothing it out i used those "rubber brushes". They are really good for that as they dont apply much pressure. Â But for the intercessors I made a mould of the Neophytes lioncloths as they were seperate from the legs so it was easier. Then i glued them to the minis and used a little bit more green stuff to fill the small gaps that might be there. Since the green stuff is still bendable after drying I also bended them a little to fit the moving motion on the mini and glued them to the leg to hold the motion. Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5755942 Share on other sites More sharing options...
Sir Clausel Posted October 22, 2021 Author Share Posted October 22, 2021 Terminators inboooound! I have for the first time in forever actually used my rolling pin. But hey it did its job so im satisfied. Anyway heres some pictures for ya! As i glued on the first shield i realised they take up so much space so the rest of the shields will be glued on after painting is done. We may not be the best assault army but I will be damned if i didnt bring some :P templargdt, Brother Carpenter, Lork and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5756419 Share on other sites More sharing options...
Bjorn Firewalker Posted October 22, 2021 Share Posted October 22, 2021 I appreciate your effort on the tabards. Their top halves (the portion resting over the Terminators' breastplates) look crude, but that's something to be fixed with practice (and patience towards those offering constructive criticism). Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5756438 Share on other sites More sharing options...
Sir Clausel Posted October 22, 2021 Author Share Posted October 22, 2021 (edited) I appreciate your effort on the tabards. Their top halves (the portion resting over the Terminators' breastplates) look crude, but that's something to be fixed with practice (and patience towards those offering constructive criticism).Constructive criticism is always welcome. Otherwise how will i learn? Anyway I somewhat agree and i will need to touch up some of it with some sanding and additional green stuff but pictures are always so unforgiving :p they always makes it seem worse than it is. Edited October 22, 2021 by Sir Clausel Lork 1 Back to top Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5756459 Share on other sites More sharing options...
Urkh Posted October 22, 2021 Share Posted October 22, 2021 Greenstuff always looks better after you've painted it as well. Regardless, your tabards are better than anything I could ever dream of making. My sculpting skills are ZERO. Good work! BLACK BLÅ’ FLY and Brother Carpenter 2 Back to top Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5756464 Share on other sites More sharing options...
Sir Clausel Posted November 3, 2021 Author Share Posted November 3, 2021 Well now theres a dreadnought put together. Since my brother is a filthy traitor I could "borrow" a cultist so my dreadnought had something to throw Brother Kraskor, Khornestar and templargdt 3 Back to top Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5760804 Share on other sites More sharing options...
Sir Clausel Posted November 27, 2021 Author Share Posted November 27, 2021 (edited) Well I just got most of the stuff I want for now. Got 2 Gladiators Im gonna magnetize so I got all the possibilities, another Crusader squad, Helbrect and Grimaldus. Only missing an Apothecary then I can make some different lists. To show of some of the stuff I have put together so far: Chaplain Hellblasters Bladeguards(Had to undercoat them so you could see the heads a little better) I really love the new kits. So much detail and extra bits for stuff later down the line. Edited November 27, 2021 by Sir Clausel Lork, templargdt, Doghouse and 2 others 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5767793 Share on other sites More sharing options...
Marshal Reinhard Posted November 28, 2021 Share Posted November 28, 2021 Knew CAB would make a great chaplain. Â That's a very zealous gathering. FW shields on the bro's and 3rd party helms? Â Still waiting on my 8 something boxes order coming in... Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5767870 Share on other sites More sharing options...
Sir Clausel Posted November 28, 2021 Author Share Posted November 28, 2021 (edited) Knew CAB would make a great chaplain. Â That's a very zealous gathering. FW shields on the bro's and 3rd party helms? Â Still waiting on my 8 something boxes order coming in... Yeah as soon as I saw him i thought: Theres my Chaplain!So I guess he is now CCB(Chunky Chapy Boy) Yup old Forge world shields and the helmets and swords are from shapeways. I really love the helmets! Cant remember what they are called. Justed searched Black templars. Â And dont worry Reinhard. Your patience will be rewarded! Edited November 28, 2021 by Sir Clausel Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5767881 Share on other sites More sharing options...
Sir Clausel Posted November 29, 2021 Author Share Posted November 29, 2021 And then there was a bolter squad With a slightly angry squad leader Tiger9gamer, templargdt, Brother Kraskor and 2 others 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5768098 Share on other sites More sharing options...
Matis Posted November 29, 2021 Share Posted November 29, 2021 If you havent found them as there is alooooot then here  https://www.shapeways.com/product/Q7UTBEMEB/helmet-model-58-freemason?productConfiguration=226435054&etId=200280981&utm_source=automated-contact&utm_medium=email&utm_campaign=order-shipped&utm_content=3     Those greathelms are fantastic, thank you so much for the link. I've been looking for nice looking and properly scaled heads like these for a while. templargdt, BLACK BLŒ FLY and Sir Clausel 3 Back to top Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5768126 Share on other sites More sharing options...
Tiger9gamer Posted November 29, 2021 Share Posted November 29, 2021 wow those claymores are big! I almost bought them for my firstborn. Awesome job! Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5768179 Share on other sites More sharing options...
Marshal Reinhard Posted November 29, 2021 Share Posted November 29, 2021 Hah, on my phone earlier I couldn't tell he was using the ancient terran (c:a M2 origin) gesture of derision for one's foe. Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5768181 Share on other sites More sharing options...
Sir Clausel Posted November 29, 2021 Author Share Posted November 29, 2021 wow those claymores are big! I almost bought them for my firstborn. Awesome job! Â Yeah they are too big for firstborns no doubt BUT! the blades are slimmer than the normal powerswords. So i wouldnt mix and match with other swords. Â Hah, on my phone earlier I couldn't tell he was using the ancient terran (c:a M2 origin) gesture of derision for one's foe. Is that a really smart way of saying "giving someone the finger"? Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5768193 Share on other sites More sharing options...
Marshal Reinhard Posted November 29, 2021 Share Posted November 29, 2021 (edited) I'm not well versed in ancient terran vernaculars. It does seem apt however  EDIT: Ok, this is skirting close to role play, so I'll stop there. Suffice to say I approve the Sword brother showing his disdain for traitors, heretics, mutants, xenos and most of all witches. Edited November 29, 2021 by Reinhard Sir Clausel 1 Back to top Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5768205 Share on other sites More sharing options...
Tiger9gamer Posted November 29, 2021 Share Posted November 29, 2021 Now all I can imagine is a grey knight knowing the best way to provoke a demon of khorne into a charge being the ancient Terran hand-gesture of the middle finger. Sir Clausel 1 Back to top Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5768208 Share on other sites More sharing options...
Sir Clausel Posted November 30, 2021 Author Share Posted November 30, 2021 So i "finished" building both Grimaldus and Helbrecht. Both converted a little. With Grimaldus i switched out the plasma pistol for a "relic" as i think it looked a lil bit cooler. Tilted the mace a bit and turned around so he is not making the "see my pretty weapon" pose. I didnt like the broken sword on the backpack so i switched it with something else. With Helbrecht i gave him the 2 handed pose by using the arms from the Sword Brethren kit. I had to trim the cloak a bit and might use some green stuff to smooth it out. I dont like the thrall helpers so i dont want to use them but im not sure what to do with the gun and also that base is huge! Im thinking of switching it for a 50mm so its still larger than usual but not this mega thing. What do you guys think? I know i wont be able to play with him in tournaments so I dont think it will be a big problem because Im not really a tournament player :P Khornestar, zarkkarn, templargdt and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5768567 Share on other sites More sharing options...
Brother Kraskor Posted November 30, 2021 Share Posted November 30, 2021 I really like them both. The Grimaldus changes are subtle but just make him seem more warlike. And Helbrecht looks so ready to ruin someone's day. Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5768578 Share on other sites More sharing options...
SWORD BROTHER RYAN Posted November 30, 2021 Share Posted November 30, 2021 I really like the Helbrect pose. I might try something similar when I pick this model up one day. Link to comment https://bolterandchainsword.com/topic/372055-the-crusade-of-the-righteous-infernus-marines/#findComment-5768582 Share on other sites More sharing options...
