Greetings, denizens of the Dark City.
During my time as an old school Dark Eldar player of the 3rd edition codex, I typically went kabal heavy or pure kabal. Huge focus on warriors, ravagers, sometimes mixed some wyches in, not always. I was usually successful, using surgical darklight and splinter attacks.
Since I have not played any 9th edition yet, has anyone gotten by with pretty much pure kabal? Blades for hire included, of course. At a push, perhaps a wych unit or two, without an obsession. Obsidian Rose would be my obsession of choice.
Essentially, can I relive the old ways of a single battalion (standard Force Organisation Chart style) of mostly kabalites with a few extras?
https://bolterandchainsword.com/topic/372192-single-kabalite-detachment-lists/
Sure, it should work just fine. The current system is designed to allow flavourful rules for the 3 sub-factions while still allowing them to operate as a single army but you don't have to use that tool if you don't want to.
Mechanised DE are pretty strong and if you want to leave most of the Wyches and Haemonculi at home for fluff reasons, your Kabalites should still work pretty well although it may leave you with a few weak areas such as melee. If that is how you like your Dark Eldar then go with it! :smile.:
If ever in doubt, just remember the first rule of Warhammer. It's your army so run it how you like. :smile.:
No, you can field modest Cult units in a Patrol which you can play around with a bit unlike other armies thanks to the split nature of the codex - but a single Wyche squad isn't going to do that much and I think breaks your Kabal obsession so it's not worth it. The mercenary units like Scourges are fine to include here, if you want Cult or Coven units it's better to do it more meaningfully I think.
You still keep the detachment type obsession, in this case kabal, just non kabal units don't get one.
  • 2 weeks later...
Cool idea! Between Kabals and Blades For Hire I think that could work pretty well tbh.
I'd probably recommend a double Patrol so that you can go with a double Court/Archon, and then both Poison Tongue venoms and Obsidian Rose trueborn / blasters / Ravagers etc.
At 2k double patrol looks like maybe:
2x Archon
2x Court (3 Sslyth + 2 Ur Ghul each)
1x 10 Trueborn (2 blasters / lance)
4x5 Kabalites (3 blasters)
2x6 Scourges (3 heat lance + 3 shredder)
2x5 Mandrakes
2x5 Incubi
2x1 Ravager (tri-lance)
3x Raiders (2 lance)
3x venoms (double cannon)
You could comfortably drop any of the Mercs for a fully 'kabalite horde' approach, but this is probably what I'd do ; )
Cheers,
The Good Doctor.
You could certainly do a battalion with the warlord and go pure kabal, then add a wych patrol for 0cp. All that requires is a wych unit and a succubus. This then gets you an obsession on both detachments, and one of the best punchers in the game (succubus is still a steal at 80pts) to go along with your wych unit.
  • 2 weeks later...
I can only join in in agreement. Kabbalites are incredibly strong. In my last tournament I managed to take down 5 big and scary tyrranid bosses with my Kabbalite army. They have weapons that pack a punch and remember, all of splinter weapons can be a threat to big enemies like carnifexes or you know, stuff that has 20+ wounds and are almost unkillable to other armies. poisoned(4+) is usually good, since it applies to any targetable enemy, even if they have T10. kabbalites also have the ObSec rule, which is really exciting, cuz if you drop the Kabs' on an objective, lets say 2 gunboats, then every model in that unit will count as holding it, which can outclass most other armies for that important objective youre fighting about that can actually mean the difference between 10 and 15 points, where the one who holds it, gets 15P for holding more objectives than the opponent. also, one last thing, insane movement, and you can fire from inside venoms and gunboats. :D :thumbsup:
Register a new account
Sign in
